Rta 12?
Mr. Bubbles
I have an opportunity to purchase a pair of RTA 12B/C ? Am not sure exactly which They have the tweeter mounted externally in the middle of the top of the cabinet. How can I tell the difference and what is a reasonable price range? Are there any specifics I should look for. Currently the guy is asking $100. It is roughly an hour drive to pick them up so the trip will cost me roughly another $60.
Post edited by Mr. Bubbles on
Go get them! I paid $120 for my RTA12C's and they are remarkable speakers. I think both the B and C variations used the SL2000 tweeter. Most will tell you to upgrade to the RD0194 tweeter which you can get from Polk but it's not necessary. Mine have the SL2000 and while they are a little bright, I can certainly live with them...for now.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
If they have peerless tweet and are in good condition it is a hard speaker to beat for the money.Speakers: SDA-1C (most all the goodies)
If all the mid woofers and tweeters work, that's a very good price!
And the crossovers are easy to upgrade to take them to a higher level of performance :biggrin:"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Can you get the serial numbers from the back of the cabinets ir a picture?? keith
going tonight to look and most likely purchase them. No pics. Guy says grilles are good and cabinets are good except a spot towards the back of one where laminate is starting to peel. I'm banking on being able to glue it back down.If con is the opposite of pro, is Congress the opposite of Progress?!
Monitor 5Jr, Monitor 5, RTA12, RTA 15TL, SDA 2A, 1c, SRS 2, 1.2TL, CRS, Atrium. -
Ok I picked these up I was a little disappointed in them cosmetically (I'd give them a 4 out of 10) but I had already driven an hour and a half to get there and hated to have a wasted trip. It would have been different if it had only been a half hour. All drivers seem to work fine. These are old and have the Peerless tweets. The labels say RT12B. I couldn't tell much about sound quality as the guy had them on top of a pair of JBL cabinets with 15 inch drivers that were on top of some tables. The tweets were not far from the ceiling. No wonder he was ready to get rid of them. Anyway, functionally they seem good and I can work on the cosmetics, but these will never be near perfect unless I re-laminate. Does anyone own a pair of these that can send pictures in detail of the top grilles. These are missing. I should be able to build some with the help of some of you guys here and pictures , measurements, and some other details. However I found a set of SDA SRA's about 10 minutes before I left to p[ick these RT12B's up so I am too wrapped up in trying to find out if I want those and maybe making that deal work to even hook the RT12B's up right now. Currently see my other post on the SDA SRS's and please give me input there. I will come back to these and hopefully get some pics, etc to fix them.If con is the opposite of pro, is Congress the opposite of Progress?!
This speaker should impress you if working correctly, forget the looks and Listen since you have them. Hopefully got them for cheap.
http://www.polkaudio.com/forums/showthread.php?t=123449Speakers: SDA-1C (most all the goodies)
I am anxious to listen but have to consider the deal on the SRS's right now. The 12's I got have the tweets set differently than the ones in the link you provided thsmith. My tweets are mounted horizontally on a very small baffle, and they have a deflector that angles downward in front of them.If con is the opposite of pro, is Congress the opposite of Progress?!
Should still sound good.
If you have a room big enough for SRs then I would not have bought or even would be looking for 12s.
You need a large room and the equip to drive srs's.Speakers: SDA-1C (most all the goodies)
My great room is 16x26 I currenlty am running my SDA1C's with a Adcom GFA 555II.If con is the opposite of pro, is Congress the opposite of Progress?!
Mine is 15x26x10. Just right for 1c's if you use the 15 foot wall. The 12s should sound great in that room.
SRS owners would have to weigh in if yours is big enough.Speakers: SDA-1C (most all the goodies)
Glad you like them. Was over at my repair guys house lastnight and told him you may be contacting him.
Sell me one of your other tube receivers and that should give you some repair bucksSpeakers: SDA-1C (most all the goodies)
