Help.... PA DSW microPro 1000 or the DSW Pro 400?!?
saa115
saa115 Posts: 6
edited August 2011 in Speakers
It seems like these two subs are running around the same price on ebay, so I was wondering, which is better?
I have the RTi A3s as both front bookshelfs and a single RTi A3 as a center (space considerations). However, the sub and sats are from the old PA RM6750 setup and I'm looking to upgrade the sub.
Can anyone recommend one sub over the other?
Thanks!
Post edited by saa115 on
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    How big is your room? The MicroPro1000/2000 sound a lot bigger than they look - I'm using my 2000 in an 11x11 bedroom and it's more than enough. But I'm not sure how well it would keep up in a large room.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited August 2011
    Same price??? microPRO, period. For the size, those things are stunning. Very solid, too.
    Welcome to Club Polk! :smile:
  • over50
    over50 Posts: 201
    edited August 2011
    I also agree. micropro. its a small sub ,but much more powerful then most subs same size. The piano black looks nice. The remote is a nice to have. Because of its small size, you can place it almost anywhere .
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
