A quick Speaker setup question.
Emew
Emew Posts: 4
Hey just a quick question here, I purchased the Polk Monitor60s from newegg recently and am going to hook them up to my Insignia 200w receiver. I only have these 2 speakers, no center speaker, no sub. Here is a link to the receiver: http://www.bestbuy.com/site/Insignia%26%23153%3B+-+200W+2.0+Channel+Stereo+Receiver/9693507.p?id=1218151628383&skuId=9693507&st=insignia%20receiver&cp=1&lp=4 I am wondering if I can do bi-amp setup. Using the 4 posts on the speakers and the 4 posts on the receiver I was planning on just individually wiring each post to an input on the receiver and using a/b speaker configuration. Is this enough wattage for the speakers to perform fair and not suffer any damage? If not, what alternate configuration should I consider? I would rather them perform safe than attempt to perform better and undervolt. I do have enough wire for any configuration! Thanks!
    F1nut Posts: 52,356
    edited August 2011
    For starters, you cannot truly bi-amp from an AVR, so best to just forget about that one. Hook the speakers up normally and replace the plated jumpers with good quality speaker wire.
  • Emew
    Emew Posts: 4
    edited August 2011
    So what would happen if I hooked the bottom set of posts to the b set for l/r and chose to use both a/b at the same time for sound?
    F1nut Posts: 52,356
    edited August 2011
    Your speakers would receive sound from the B connection.
  • Emew
    Emew Posts: 4
    edited August 2011
    Would this supply more power to each speaker though is my question?
    F1nut Posts: 52,356
    edited August 2011
    No sir.
