Should I plug my amp into my conditioner?
myke
myke Posts: 138
edited October 2011 in Electronics
Both of which I am buying soon, the answers I receive along with constant reading will decide exactly which ones I buy (emo xpa-5....panamax 5100 or apc H15).
So I have been reading not to plug it in b/c of many reasons, limiting power to the amp, over loading the conditioner with other gear on at the same time, amp should be on a separate circuit, and a few more.
On another crazy note :biggrin: (no but really) should I buy a 20 amp breaker and run a new recep to the living room for the amp (with/without conditioner?)?
Any thoughts?
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
Post edited by myke on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2011
    Just don't. There's enough natural filtering and use the power conditioner for everything else.
    Dedicated breakers are a good idea but not neccesary, just a tweak. Unless the conditioner has a non-current limiting circuit, use the wall. Don't overthink everything just based on what you read the other day. This is not a hard hobby.
  • myke
    myke Posts: 138
    edited August 2011
    The conditioner does state it has a high current outlet for an amp (or sub). But, if I add all the watts on the back of all gear including the 1000 watts for the amp and divide all watts by 120 I get 18.408 amps?? Is that right? Wouldn't I need a 20A conditioner.....this can't be right:confused:
    "2 outlets for equipment with high power demands (Amps/Subwoofers)."
    "3 isolated banks:
    one isolated bank of four switched outlets
    one isolated bank of four always-on outlets
    one isolated bank of two switched high-current outlets with delayed on/off "
    I do tend to over think things but the last thing I want to do is make the wrong purchase/decision. I have read that Emo's position is to go directly into the wall due to fuses built in for surge protection (then i'd have to replace the fuse) but another level of protection couldn't hurt, right? Voltage always varies so much from the wall a constant 120v flow would be nice. However, I wouldn't want to limit the power draw either in case I want to go deaf......or whatever.
    Am I reading correctly that since the XPA-5 is an A/B amp it's not efficient as a class D therefore doesn't actually draw the full 200 watts??
    What about a new dedicated 20 amp circuit just for A/V equipment, that couldn't be too hard or expensive, right (well maybe thats overkill)?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2011
    myke wrote: »
    Then why are you considering Emo? :biggrin: Just kidding.
    I also have read posts here saying not to plug amps into the power conditioner, although good technical details to back up the post have been missing.
    Anyway, both of my amps are plugged into the high current ports of my Panamx M5300-EX, and, to me, it sounds great. Of course, since I only have one wall socket (2 receptacles) on the wall, and the power conditioner uses one, I really do not have much choice about where to plug in the amps. Also, the Wadia iTransport, SACD player, DAC, and pre-amp are plugged into the Panamax.
    I mostly listen to classical in the 70-80 db range, and sometimes a little lower. On the other hand, I will sometimes listen to rock, and variants, in the 90-100 db range, even a little louder sometimes. In both of those situations the music sounds great, and I never felt the power conditioner was negatively affecting the sound. If it is then it is a very small effect.
    So, to answer your question, if you can try both ways then do it, and see if there is any difference. If not, and you expect the power conditioner to provide some type of benefit, then use that.
  • myke
    myke Posts: 138
    edited August 2011
    Funny:rolleyes: First amp, just really starting to get into things, also self imposing a limit of funds on this first setup. When I get the theater room then we can talk:cool:!
    I'm actually looking at the Panamax 5100 vs. ACS 15H.....they kinda seem similar except I haven't seen a statement on the APC site that says it cuts off power like the Panamax makes it a point to state it everywhere and the APC has a higher Joules rating. Has anyone noticed other differences in those two?
    And of course when i'm only using a $30 monster power strip I would lose power in the hurricane briefly today, luckily only the tv/cable box was on!
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • Marty913
    Marty913 Posts: 760
    edited August 2011
    myke wrote: »
    Actually the APC takes it a step farther as the H15 is a voltage regulator. For voltage over/under situations the H15 adjusts the voltage to avoid a shutdown. Only when voltage goes outside of the adjustable range does the unit shut down (I believe the range is roughly 90 - 140). The Panamax and Belkin have "brickwall" type protection but do not adjust voltage.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • engtaz
    engtaz Posts: 7,669
    edited August 2011
    I have seen were conditioners limit the amps ability by limiting current to the amps.
    engtaz
  • myke
    myke Posts: 138
    edited August 2011
    Marty913, thanks I forgot about that. I wish it had a trigger too. It seeems to be better in joules too so I wonder what is the benefit of the panamax compared to the APC 15H?
    engtaz, how did you see or know amps were being limited, did you hear it or see it on the meter?
    I suppose I am concerned if I don't use the conditioner and plug directly into the wall that all of this is going into a 15amp circuit......
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • dekuda
    dekuda Posts: 756
    edited August 2011
    myke wrote: »
    15 amp line will be fine,that is what I have. The wattage on the back of your equipment is your max rating . Unless you have really old house wiring you will be fine.
    As far as direct feed into the wall, there are some amp manufactures that have it in the amp's operator manual to not use any filters/conditioners but to plug right into the wall. Bob Carver himself highly recommends it for many of his amps.
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • Marty913
    Marty913 Posts: 760
    edited August 2011
    myke wrote: »
    The H15 does have a trigger from one device (your receiver) that can control powering up two other devices (amp, sub-woofer, etc.). I did look up the voltage regulation range and it is variable (your choice) up to a maximum of 92 - 144 volts. It does have two "high current" outlets which I would assume are not limited but who really knows.
    I'm not recommending one device over another, just trying to help out with specifications & features.
    TT = Audio Technica
  • pietro944
    pietro944 Posts: 720
    edited August 2011
    No....you should shampoo first(sorry,couldn't resist).
  • myke
    myke Posts: 138
    edited August 2011
    so reading more on this subject I've been finding out any major surge or lightening strike close or direct could go right through any conditioner/surge protector..........which kinda sucks!
    I read a pretty interesting idea of using a SA20 by SurgeX and then plug in your conditioner...otherwise I better hope for a small surge if I get one or simple power flucuations. I was wondering if anyone had any thoughts on this and if a panamax might be the best route, even w/out power regulation at least it might cut off in time before the surge goes through....? The I guess replace the conditioner if i know it happened (which means the mov)?
    any thoughts?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • Face
    Face Posts: 14,340
    edited August 2011
    A line conditioner will limit dynamics.
    EndersShadow Posts: 17,692
    edited August 2011
    myke wrote: »
    At the end of the day this is what insurance on things is for. Homeowners, Renters, etc.
    You cant protect your gear from everything, hence the concept of insurance. You can only plan for so much and just play the percentages. Likelihood of a direct strike, low, likelihood of quick power outage/brownout/low voltage much higher
    Toolfan66 Posts: 18,005
    edited August 2011
    If your that worried about it unplug your rig when not in use. I use a PC because it cleaned up the line noise.
  • myke
    myke Posts: 138
    edited August 2011
    Yeah I figured as much, and its not like i'm crazy concerned but as i'm spending more and more i'd like to know i've given serious thought into my options, so basically all i can hope for is noise filtration, low voltage surge protection, brown out/storm protection, low voltage regulation, etc....
    As for Ins., it isn't really a practical option to rely on since the deductable would be rather high and so unless a lot on gear is fried it doesn't serve a purpose ( thats def for WORST case scenario:eek: )
    Grew up in FL so i've seen TOO MANY lightening hits (direct/indirect) and power flucuations, now live in NC which is better but still hit more than most states statistically (going back to playing percentages).
    Regardless I appreciate all advise and thoughts.......
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • myke
    myke Posts: 138
    edited August 2011
    I was actually thinking of unplugging it too during those crazy times but figured either A. I would lose some setups/cnfiguratins or B. would just forget, which is prob far more realistic - got to consider myself too in potential accidents
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
    edited August 2011
    If I'm home and we get some crazy weather I unplug my rigs if not I don't worry about anymore. At first I put more energy into so much dumb crap with my rigs that it starts to take some fun out of it..
    Get a good PC and sit back and enjoy!! You should have a good PC if your pluging in a TV it will give you a better picture and give you some protection..
    tonyb Posts: 33,068
    edited August 2011
    I had a lightning strike about 150 ft away. Toasted my Monster 5100 PC, and the cable box, but saved all the other electronics. I always just unplug the amp when a big one rolls in. Lightning hits work in strange ways, they kill some stuff, while leaving others alone, even if all are plugged into a PC.
    PC can do good things for video and line noise, smaller surges, but direct hits will toast them.
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    I'd get an estimate on some dedicated lines to your listening room, mine was close to the main box, so it was only $250 for two dedicated, properly grounded (important), 30amp lines with two 4-plug receipticles. Money well spent since ML speakers need a plug socket just for them. If your home has dimmer switches on the same line it's just nasty stuff, same with your computer, A/C unit and the fridge. I didn't bother looking at conditioners, I just went straight to the electrician when I moved in, and I'm a renter who plans on staying awhile, so YMMV.
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • stangjason
    stangjason Posts: 341
    edited October 2011
    How can a conditioner limit an amp when your wall outlet is usually 15 amps and sometimes 20 amps?
    Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
  • falconcry72
    falconcry72 Posts: 3,580
    edited October 2011
    I think it depends on the conditioner.
    I use an APC-S15; it's rated at 900W/1500va, and it's always done me right. :smile:
    Every single piece in my 2-channel rig (see sig + my comuter) is plugged into this thing, and at full reference volume, the APC says I'm only using about 550 watts out of the the 900 available, so I'm not worried about losing dynamics in the least, in fact, everything sounded better as soon as I got this thing a bout a year ago.
    Another cool feature is the battery backup. At full reference volume, the included battery could run my entire system for 30 min! That's impressive given the amp, powered sub, and hard to drive maggie 3.6's. More importantly, it could drive my wireless router, modem, and computer for days. That could come in handy in a power outage.
    I actually tried this once, but I don't encourage it:
    OK so everything wass plugged into the APC-S15 PC, and the APC was the only thing plugged into the wall. I turned everything on, which at the time included a TV and receiver in addition to the 2-channel step, and yanked the APC's power cord from the wall...
    Nothing skipped a beat. The battery backup kicked in seamlessly, and you wouldn't have even known what I did had you been watching the TV or listening to the music.
    In my particular situation this thing comes in handy a lot, because sometimes when the HVAC kicks in, the lights in the basement dim a little, and there's obviously a strange signal being sent to the APC because I can hear the APC turn on and "do" something, but the music is never affected.
    YMMV
    Cheers,
    Ben
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    What if your amp draws 1500w @ reference level?
  • falconcry72
    edited October 2011
    Drenis wrote: »
    Then you would need a more capable conditioner...
  • zingo
    zingo Posts: 11,258
    edited October 2011
    Drenis wrote: »
    I use the Tripp-Lite LCR2400 which is rated at a peak 2400w and 20A. I bought it specifically because it has voltage regulation and will not limit current to my system.
  • Marty913
    Marty913 Posts: 760
    edited October 2011
    Drenis wrote: »
    I have a Carver 705THX 5-channel amp, 60" Sony, Dish cable box, music steamer, Bluray player, a few other small devices plugged into my Belkin PF60. With all on and cranked to a fairly high listening level I barely draw 4 amps. If your amp is drawing 1500 watts you need to have it check out pretty quick.
    TT = Audio Technica
    edited October 2011
    I just connected EVERYTHING in my sig to my APC H15 and my display is showing only 47% usage with 720 VH with EVERYTHING on and running while watching LOTR on blu-ray at a pretty decent volume.
  • angelsfann02
    angelsfann02 Posts: 589
    edited October 2011
    myke wrote: »
    Any thoughts?
    If you have the cash, what the heck, I say run a dedicated 20-amp circuit for the amp. You could also use it to power gear that draws less power with that circuit too. Thats the route I went.
    I have my Emo plugged into a Panamax which is plugged into that dedicated receptacle. Sound great to me. I tried and tried but could not hear or see any difference with my Xpa-5 plugged directly into the 20-amp plug vs. using the Panamax. So it remains connected to the Panamax conditioner/surge protector.
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    Marty913 wrote: »
    My Carver TFM-42 lists on the back that it's max rating is 1500 watts. Christ it has headroom for 750w per channel and does get power hungry when requested. To be honest I think I've already stressed my circuit once.
    I too, need to look into a power conditioner unit. I live in a very old house with upgraded service, panel and most wiring (I say this because I base that on what I can see has been done. I think 80% of the wiring has been upgraded at the least)
    My problem is I have a shared circuit Im sure. Cause when I turn my kitchen fluorescents off... I sometimes get a small pop sound my from speakers. Even with the amp turned off.
