Pb2-isd
tschep20
I have an svs, and have a Monster bass 300, works great i guess// sub cables don't really have to be much more then shielded well and have quality connections, either cable will work fine and similiar, my answer is somewhat what i got from Dr.spec when i asked this same question, I have the same size room as you basically and the pb1 does a great job.... the pb2-isd will smoke that room with base and spl.......MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
okay thanks, i just wanted to make sure that i wasn't going to be missing anything with the cable i have
You will do backflips when you hear what this sub is capable of. Let me know if I can help you with set-up!"What we do in life echoes in eternity"
SVS -
Actually i called back and changed my order to a PB2-Plus. I figured the difference was only $360, so i went ahead and got that one. I mean $360 more for better drivers, 50% more watts (600 to 900) is well worth it. And Dr, I'll let you know if i need any help, which i probably will.
One more thing, what disc do you guys recommend for setting up speaker calibration? -
Good on ya!
Try the new Digital Video Essentials.
Doc"What we do in life echoes in eternity"
SVS -
what about the equalizers svs offers, did any of you purchase those, or are those not necessary?
Unless you have a nasty peak at the listening position, you won't need a parametric EQ. Experiment with placement and only use EQ to tame room peaks as a last resort. They can be very useful, though."What we do in life echoes in eternity"
SVS
