RTI4's with CS1 (or CS180) - timbre matching question
edited September 2011 in Speakers
I have a pair of RTI4s (superseded by RTI A1). I am thinking about getting a center speaker to go along with my new TV.
I read that the CSi A4 matches with the RTI4 and the CS1 or CS180 matches with the TSI/Monitor line.
I'm on a budget, so I am thinking about picking up the CS1 or CS180 which can be had for $100. The CSi A4 costs around $279 on special here in Canada, so it is too pricey.
How noticeable will the difference be? The other choice in my price range is the Klipsch Icon VC-25.
Post edited by ranger101 on
Welcome!
    Any advice here guys (or gals)?
    Welcome to Club Polk!
    The match for the Rti4 is the CSi 3 or 5, you can also use the newer line the CSi A4 or A6.
    You can use a CS1 but it will be a tad off. Probably a little 'darker' sounding than the tweeter in the Rtis?
    What is a CS 180?
    cnh
    Thanks for the help.
    (CS180 I believe is a version of the CS1 sold by Future Shop in Canada.)
    No need to thanks us...that's why we're here.
    I believe you could probably find a CSi 3 (the previous version of the CSi A4) used for around a 100 or less online, ebay, or whatever the equivalent of craigslist in Canada is?
    Sometimes members here sell theirs on the forum. That's how I picked mine up. I use it with two Rti A3s as the front stage in my basement system.
    cnh
    I would hold off on the CS1 as it doesnt really timbre match your RTi's. I would agree with cnh to try and find a used one at a reasonable price online. Good luck.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
Welcome!
Welcome!
