Damping factor values in Amplifiers
dekuda
dekuda Posts: 756
edited August 2011 in Electronics
I have a question regarding damping factor ratings on amps. You see the values listed in the specs of every amp.And they are all over the place for differant ss amps. But how important are they?
As I understand, a high damping factor indicates that an amplifier will have greater control over the movement of the speaker cone especially at low frequencies (20Hz) and therfore a higher value you would think would be better. But the damping factor is also dependant on the resistance of the voice coil in the speaker and the output impedance of the amp itself. Maybe also if you have cheap speaker cable the resistance of the cables might also lower damping factor. So there are other factors.
Here is my main question, do high damping values in solid state amps indicate high levels of negative feedback design(to control distortion) by lowering the output impedance of the amp? Is this a bad design? Some have disliked the high levels of negative feedback in amps (therefore higher damping factors).
Here is the thing, I am looking at two amps. One having a damping factor of >150@20hz and the other having a value >1100@ 20 hz. Will I be able to tell the differance? Especially since the amps is only driving my fronts with everything above 80HZ (Everything below 80HZ is redirected to my subs) Is a damping factor of greater than 150 good enough? And maybe a better design?
Thanks,Dave
HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
Post edited by dekuda on
    mhardy6647 Posts: 34,982
    edited August 2011
    It is nothing more (or less) than a measure of the output impedance of the amplifier; DF is the ratio of the nominal load impedance to the amp output impedance. A DF of 100 into an 8 ohm (nominal) load means the amplifier's output impedance is 8/100 = 0.08 ohms (80 milliOhms).
    It is essentially a useless specification for a couple of reasons: the nominal impedance of the load is just that (nominal) for most types of real-world loudspeakers (although there are some loads - most ribbons and some planar drivers - that behave essentially as purely resistive loads at audio frequencies) and low output impedance was (!) traditionally obtained using very high levels of global negative feedback.
    That said, it is possible to apply feedback carefully or indiscriminately; one cannot simply conclude "global negative feedback is bad". It is also possible to lower output impedance in other ways (e.g, paralleled output devices), so there's no easy blanket statement.
    Generally, though, DF per se -- like many hifi specs -- is "a great sound and fury signifying nothing" IMO.
    FWIW, I'd recommend that you stop "looking at two amps" and start "listening to two amps".
  • Systems
    Systems Posts: 14,873
    edited August 2011
    @dekuda..check this link out...it should help you understand more about amps ..Damping...of -/+ return of the current too and from you speakers..http://www.audioholics.com/education/amplifier-technology/10-things-about-audio-amplifiers...
    Testing
    Testing
    Testing
    edited August 2011
    FWIW - There are factual mistakes in that link (e.g., in number 7, the author confuses harmonic distortion spectra of single ended vs. push-pull topologies with vacuum tube vs. solid state distortion spectra)... so I'd recommend reading it carefully, critically, and amply cross-referenced.
  • Systems
    edited August 2011
    @mhardy6647..+1...@7 in the link...post read...check factual..where his input not fact..OP was asking about Damping..didn't Sony on there ES line..stop using that class amp..push/pull?..
    Testing
    Testing
    Testing
  • dekuda
    dekuda Posts: 756
    edited August 2011
    Thanks for your feedback! If I could get both amps and compare them that would be the solution. But costs being what they are that is not possible at this time. One of them is available,Parsound 5250. The other one I missed my chance on,a Parasound 2205AT. Both good amps but huge differances in damping at 20hz. Do not know why unless the 2205at is that much better of a amp. But like you said if it not a important factor then I will not worry about it.
    HT System
    heiney9 Posts: 25,430
    edited August 2011
    Damping factor is overrated. Tube amps tend to have lower damping factor than SS amps, the numbers the manufacturers give 1) aren't all measured by the same procedure 2) anything over 200 is good and the higher number has very minimal impact on the entire equation 3) these measurements aren't taken in real world use. ie; just looking at damping factor as criteria to purchase one amp over another is ludicris since there are many, many other more important factors.
    Sure a tube amp with a damping factor of say 25 and a SS amp with a damping factor of 300 might sound different, but there are many other factors that could be at work as well.
    Another term everyone gets wrapped around the axel about is slew rate, another pretty much meaningless measurement that people like to either quote or use as the basis for buying one amp over the other.
  • cristo
    cristo Posts: 231
    edited August 2011
    ctank wrote: »
    This link from the above one talks about damping factor specifically.
    http://www.audioholics.com/education/amplifier-technology/damping-factor-effects-on-system-response
    Two point to throw in
    - once the DF is above 20-50, higher numbers result in increasingly vanishing differences in performance.
    - a DF of 1150 is > 150 and >1100, so it's possible that there might be no actual difference in the DF of the amps cited by the OP.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • dekuda
    dekuda Posts: 756
    edited August 2011
    heiney9 wrote: »
    I agree that there are much more important considerations in buying a amp. But I was just wondering why the numbers varyied so greatly between two amps made by the same manufacturer. I basicly got my answer here and I thank all of you for responding. Notice, I was only refering to solid state amps.
    HT System
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2011
    I have amplifiers with adjustable damping, this is truly something that improves sound quality....as it tailoring the to the individual pair of speakers. Application improves speakers Sound Qualtiy across the board whether entry level or something more esoteric...so dampening in itself is important, just as current flow, however, I dont rush see what a manufacturer lists as there are problems with the spec as previously posted about.
    RT1
    edited August 2011
    RT1
    Is that on a modern amp? That's interesting.
    Adjustable damping on some of the better vacuum tube power amps wasn't uncommon in the late 1950s/early 1960s, but it pretty much disappeared thereafter. Didn't know it had made a comeback.
    Here, e.g., is a 1959 Knight (Allied Radio Corp.) EL37 push-pull mono power amp with variable damping (0.5 to 50).
  • reeltrouble1
    edited August 2011
    2001 model so "new" in comparison to the 40's-50's. I was actually a bit suprised at the difference in SQ heard at the Fest in 09 when we hooked them to some Tsi500. Micah and I were doing some listening and the tsi were bloating, a bit of adjustment and the bass tightened noticeable. The circuit was designed by Henry Wolcott, the Wolcott were built to run Roger West's speaker design which have impendance swings near short circuit. His designs present a diffulcult load and I had initially purchased and used them for the Sound Lab. I suppose another example of applying older proven techniques to a circuit.
    RT1
  • zingo
    zingo Posts: 11,258
    edited August 2011
    I also have many issues with that article. It's an interesting read, but not gospel truth.
  • Timothy Smith
    Timothy Smith Posts: 764
    edited August 2011
    I would agree that it is far more important to listen than to read and compare specs.
    The two primary sollis state amps I use have wildly different damping factor "ratings".
    My old (1967-1979) solid state McIntosh MC-250 is 50 watts/channel and is listed as having a damping factor of only 38 at 8 ohms.
    My modern solid state Rotel RB-1080 is 200 watts/channel and is listed as having a damping factor of 1000 at 8 ohms.
    I prefer the bass response of the McIntosh over the Rotel in many cases with speakers that usually have "tight" (at least not flabby) bass response characteristics like A/D/S, Dahlquist, Canton, etc.
    Maybe in some situations a "loose" amp compliments a "tight" speaker, especially if you don't use a separate subwoofer, Also maybe since most of the preamps I use (Antique Sound Labs Line 1, Forte 44, Cayin TA-30 do not have any tone controls or loudness buttons that would let you boost the bass.
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
    edited August 2011
    Some interesting info above. As for damping...those specs are all over the map. Some great amps have damping factors that aren't as good as some crappy amps and vice versa. Trust your ears first.
    But Ted's unit? The ability to match or adjust damping to a particular set of speakers...that is pretty cool!
    As per mhardy's post though, isn't almost all your stuff 'tube' gear, Ted? I guess what I mean is; does anyone know of any SS gear that allows for such adjustments?
    cnh
  • reeltrouble1
    edited August 2011
    of course my gear glows...Tubes Rule.
    RT1
    treitz3 Posts: 19,975
    edited August 2011
    Amen.
  • John K.
    John K. Posts: 822
    edited August 2011
    The technical study by Pierce linked in #8 above illustrates that damping factor is rarely of audible significance in modern amplifiers. Factors anywhere in the double digits are sufficient to reduce any problem with a peak at the bass resonance frequency to insignificance and to maintain decay time at inaudibly low levels. Factors of 20, 200 or 2000 are all fine and only manufacturer hype lends imaginary special significance to the higher numbers.
    The only modern exceptions to the insignificance noted would be some tube amplifiers with output impedance of several ohms, resulting in damping factors around 1 or 2. With well-designed equipment this is another of the effects that can be measured but can't be heard.
  • dekuda
    dekuda Posts: 756
    edited August 2011
    John K. wrote: »
    Thanks John K for a precise a definitive answer. It was not that I considered this a major reason in choosing a amp. Far from it. I just wanted a explanation on the wide varience of values given and what if any differance it would make to the sound. From the answers here it looks like it does not really matter that much.
    HT System
  • scottyboy76
    scottyboy76 Posts: 2,905
    edited August 2011
    another area where adjustable damping is important is your chimney flue,
    left it closed once after starting a fire, it was like a lucy episode.
    hope this info helps.
    humpty dumpty was pushed
  • DON73
    DON73 Posts: 516
    edited August 2011
    dekuda wrote: »
    Thanks,Dave[/QUOTE
    You won't hear a difference caused by the damping factor. Yes a damping factor of 150 is good enough.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • 20hz
    20hz Posts: 636
    edited August 2011
    DON73 wrote: »
    dekuda wrote: »
    As I understand, a high damping factor indicates that an amplifier will have greater control over the movement of the speaker cone especially at low frequencies (20Hz) and therfore a higher value you would think would be better. Yes a damping factor of 150 is good enough.
    I was told dampening factor is only real important for a subwoofer amp , but a weak dampening factor is helped if your desired amp has more wattage than you need .
    I would think for your desired amp running above 80 hz you will hear a cold/weak sounding amp first .
    Amplifiers sound quality is a very personall thing , I think to make a good decision look for a largest majority of favorable votes .
  • dekuda
    dekuda Posts: 756
    edited August 2011
    20hz wrote: »
    DON73 wrote: »
    I do not understand, why would the amp be weak/cold if I am driving the speakers above 80HZ. From most everyone's response, I should have no concerns.
    HT System
  • skrol
    skrol Posts: 3,448
    edited August 2011
    What factors make an amp a "fast" amp? I guess I wrongly assumed that this was related to damping factor and slew rate.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • 20hz
    20hz Posts: 636
    edited August 2011
    dekuda wrote: »
    20hz wrote: »
    Just a bad sounding amp , like it has no warm midrange .
    For example I had a onkyo 501 it sounded bad compared to my adcom .
    I would play a cd for a whole side and than try the other amp adjusted to the same volume .
    Well some people base their decision completely on other peoples opinions
    ( I dont know if you do that ) but if you do look at it as a majority for example 90% of the people really liked this certain amp .
