Issue with sw122 from 3.1TL
cayovelez
Hello All,
I just got a fairly decent shape 3.1TL upgraded by prior owner. So far I have not listen to them with my gear but did so at the guy I got them from house. He used all SonicCraft and mills. I just got around to check all the drivers and job he did on the crossover and noticed that one of the SW122 is not right, he used duct tape to hold the cardboard on the back of the basket. Also, they both seem to be missing the dome on the rear. What can I do?:eek:
Post edited by cayovelez on
Take the tape off and glue it down if it bothers you. If it was me I would just take it off both of them and replace with dynamat extreme.
There is no dome on the back of the 122's.
Hope that helps. And congrats on the 3.1's!!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Thanks Larry,
It I am planning on using Dynamat when I install the rings I got from you(thanks). As far as the dome, I was going on the 1C's I had which they had that dome or weight. Thanks for the info.
Carlos -
The weight is inside the dustcap on these passives..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
