What do you set your Monitor70 and CS2 crossover frequency at?
kazaam
kazaam Posts: 92
edited September 2011 in Speakers
Audyssey set mine all at 40 hz. Any suggestions/opinions?
Thanks!
Post edited by kazaam on
  • 67jason
    67jason Posts: 57
    edited August 2011
    I run my set up (70s, 60s, and cs2) small at 80 Hz or full band 70s only for 2 channel stereo. Experiment between about 40-80 Hz and find what sounds best to you with your gear in your room. It took me a couple of months of tweeking (speaker positioning and xover settings) before I found what suited me for my set up in m room.
  • Glowrdr
    Glowrdr Posts: 1,103
    edited August 2011
    Generally you want to start at 80 - that works for most people. With the 70's you could go to 60, but I wouldn't expect them to dig too deep. I can't remember what sub (if any) you are running. If you are in fact running one, you might as well let it do it's job, and free up some headroom for the rest of the bandwidth.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    edited August 2011
    Agreed! What kind of AVR are you running because that will have some effect on how much it can 'drive' the towers? Having said that, I do run mine at 40 hz and everything else at 80hz, although I find that for some soundtracks my CS2 likes to be at 60hz?
    As said, experiment and see what sounds best to you. I know the basic advice is to run everything 'small' and let the sub relieve the AVR from the strain of low bass duty. But I just don't like what I hear at 80hz all the way around in my room.
    cnh
  • Systems
    Systems Posts: 14,873
    edited August 2011
    THX...say's 80hz for sounds..and depending on your front (mains) ..being if they are Towers..or bookshelfs?..i have tryed setting my mains to large and found that when playing a Blu-ray in Master..DTS..i was getting a (sub) phase issues.THX will tell you that if and i can not say if this is true ..you will lose surround information if your surrounds are not set too 80hz..
    Testing
    Testing
    Testing
  • kazaam
    kazaam Posts: 92
    edited August 2011
    My receiver is definitely not that great. I have a sub on order (should be here within a few days; eD A2-300) that should be pretty good. I'm thinking about bumping my CS2 to 80hz and my M70s to 60hz. Good? Or should I go 80 all around?
  • Esreuter
    Esreuter Posts: 176
    edited August 2011
    Kaz,
    let your ears tell you that answer.
    :cool:
    ESR:biggrin::biggrin::biggrin:
    AVR: Sony 5600ES
    Center: CS2II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Front: Monitor 70 II (Clarity Caps PX, Perfect Lay coils, Mundorf resistors)
    Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Rear Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    More to come :biggrin:
  • Systems
    edited August 2011
    @kazaam...i have my M70's set too full in HT and my center and surrounds set to 80hz..only because my sub Polk 10 is weak which i will upgrade soon too the Polk 505..but i think when you do get your sub in and i believe it is a lot better then the Polk PSW 10..it will handle the low end in your surround much better..so setting your M70's too 60hz should be ok..but have too agree with Esreuter...play around with it some and let your ears tell you what you like....its a choice..some people like adcom..carver..b&k...EMOTIVA..sonyes..or even a lil parasound amp..its a choice..
    Testing
    Testing
    Testing
  • fyrn
    fyrn Posts: 146
    edited August 2011
  • Lietuvis91
    Lietuvis91 Posts: 908
    edited August 2011
    center at 80hz and m70s at 60hz is where mine sound best with the sub I have
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2011
    if running for HT I used to set at 80Hz and let the sub take over from there. For 2 channel I would run full range and no crossover.
    Test it out and see what sounds the best to you there is no wrong answer really.
  • Shan87
    Shan87 Posts: 12
    50hz for mine.
