3 channel amp
fyrn
I need some recommendations on good brands/models (new or old) for a 3 channel amp to drive some LSI's. Other than the emotiva xpa-3.
Post edited by fyrn on
Now you're talking my language fyrn. What's your price range like? If you're on a budget, might look at a 3 channel Acurus,Parasound,B&K,Rotel or Adcom amps? Aragon made a sweet 3 channel amp too.(might be pricey though). You might look at running 3 mono amps like the Marantz or Outlaw Audio.
Sunfire, Outlaw Audio, Parasound, Rotel are some to name a few. Check out Audiogon.Shoot the jumper.....................BALLIN.............!!!!!
Stick around here fyrn, some of our fellow CP members might be able to fix you up with some nice used gear:)
In fact, check the for sale section. Someone's got a pretty good deal on an Adcom GFA-5503 right now, and that would work nicely with the LSis. Hell, if I had money right now, I'd pounce on it just to power my RTi70/CSi40 front soundstage.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
there's a parasound 2003 on audiogon as well (300w x 3, 4ohms). I didn't know any 3ch parasounds existed!Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Polkie2009 wrote: »Now you're talking my language fyrn. What's your price range like? If you're on a budget, might look at a 3 channel Acurus,Parasound,B&K,Rotel or Adcom amps? Aragon made a sweet 3 channel amp too.(might be pricey though). You might look at running 3 mono amps like the Marantz or Outlaw Audio.
Well I can get a new emotiva xpa3 for $600 so maybe something used in the 200-300 range would be good -
300 is probably more realistic, $200 would be great. I think for couple hundred I'll go with the emotiva new. If anybody has an XPA-3 they want to sell send me a PM
Carvers can be had in that $$ range. Here's a sixer that can bridge to three.
http://www.ebay.com/itm/Carver-AV-806x-THX-6-Channel-Amplifier-Rare-No-Reserve-/280728213679?pt=LH_DefaultDomain_0&hash=item415cb498af -
Thanks gdb, I'll research it, anytime something is describe as rare = old -
Let me ask a "stupid" question since I'm new to separates. The LSI"S (7 or 9) specs say amp requirement is up to 200 watts. Anything bad if you hook them up to a 300 or 400w amp. Obviously I'm not going to play it full blast, buy just the amount of watts present
Good luck with the Emotiva...
Polkie2009 wrote: »Good luck with the Emotiva...
Does that mean I wont be able to find anything for less than $400... -
@fyrn...Emotiva amps are good..i have two UPA-1,s and they have a really good sound too them..200 watts and lots of headroom..anything else for (new) will run you 1K..but if going (used) then may the power of the watts be with you.Testing
Testing
Testing -
Parasound should smoke the emotiva
http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1319001034&/Parasound-HCA-2003-200w-x-3Shoot the jumper.....................BALLIN.............!!!!!
You're going to have a tough time finding a 3 channel amp for $200-$300. The suggestion of buying a 6 channel amp & bridging it would be a good one, if you weren't hooking it to 4 ohm speakers. Most will not be very happy trying to drive that load in bridged configuration. I've owned the Acurus A200x3 before & currently have its big brother, the Aragon 8008x3. Both are great but above your price range. Closer to your range would the the Acurus 100x3. If it's anything like the 200x3, it would be a solid choice.
-Dave -
Honestly... I went thu the 300ish amp price range thought process....bought and sold two Adcoms. I took the next step in price and have stuck with the 2003 since. -
+100 on what kevhed72 suggested. Save some more and go the next step up in price. You'll be glad you did.
not true. I can easily get amps that cost less than 1K new, may not be the best in SQ but they do happen to be out there. -
Remember when your parents told you..."You get what you pay for." Well, 'nuff said.HT SYSTEM-
lsi 9's -
Cept when that kitchen staffer bought that sweet Benz for a measly 20 bucks!:eek: I'd have to say that sometimes, that old adage just doesn't hold true!
I've seen probably 3 Adcom three channel amps on Ebay in the last week.Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier -
jojomgee just had a Adcom Gfa-5503 right here at CP Flea Market ,looks like he had to take to Ebay to sell it though???
what would you say is the "least" amount of watts for the LSI9's to do well
these speakers you ask of say they're rated for 20-200. so if it's 200 x 3 for the amp that'd be perfect. but really anything in between would work.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
welcome to Club Polk too:)Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
