dynamating RTA 12c's
soundfreak1
In a word WOW! Tightened bass up way beyound expectations! Punchier, faster, deeper, brought the mids right out of the cabinets. Very surprising. The B's are next! Seems to open the sound stage up quite a bit. Those of you that have hessitated as I did
don't! Cheep at twice the price. BTW. Has anyone spiked your 12's like some feedback on how long a spike u used ( have carpet) but I'm a little concerned about stability, considering making some ourriggers insread. Anyone tried that?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
Reminds me I need to do mine. Are the RTA12s on a stand? I do not have any for mine and need to make some, do you know the demensions ?Speakers: SDA-1C (most all the goodies)
what all did you cover with the dynamat?If con is the opposite of pro, is Congress the opposite of Progress?!
Monitor 5Jr, Monitor 5, RTA12, RTA 15TL, SDA 2A, 1c, SRS 2, 1.2TL, CRS, Atrium. -
oliverbubbles wrote: »what all did you cover with the dynamat?
Yes, please do tell. I am preparing to rehab a pair of RTA12's and am considering this as well.Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd). -
thsmith - I have stands - can take photos and dimensions if you want.Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
Michael8it wrote: »thsmith - I have stands - can take photos and dimensions if you want.
Yes please and thank you.
oliverbubbles, When I dynamat'ed my 1Cs I did the spokes on the basket and the top circle the spokes connect to just below the magnets.Speakers: SDA-1C (most all the goodies)
soundfreak1 wrote: »In a word WOW! Tightened bass up way beyound expectations! Punchier, faster, deeper, brought the mids right out of the cabinets. Very surprising. The B's are next! Seems to open the sound stage up quite a bit. Those of you that have hessitated as I did
Plus 1 on the dynamat! And the Xover upgrades, rewiring, installing hurricane nuts and socket head cap screws on MW's and PR's, and spikes.
On the latter I used the small ones from Parts Express. They're solid brass and short.
I wanted 'em short because I, too, am concerned that the speakers are a bit top heavy. But I'm not putting them on carpet, only on wood, so they don't need to be long."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I am not set up to make the outrigers my self. Looks like a machine shop could cut some steel, slot them and drill them fairly Cheep than just need spikes. Maybe paint or a bike shop ( or paint shop) to powder coat if wanted. Doesn't look like rocket science. I'll look around my area and aee if its reasonable cost wise.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
As far as covering with Dynamated goes I winged it. Just covered the metal baskets on the drivers. Prob over did the pr's but the mids were easy saw a good pict. Of someone else's in the diy forem and cipher his .Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Correction: picts were on this forem by darqueknight under heading : SDA DRIVER SEALS....Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Thanks for the description!Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
Be aware, I've learned through another thread and confirmed thru polk that the risers on rta 12's are hollow and may not support spikes without reinforcement.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »Be aware, I've learned through another thread and confirmed thru polk that the risers on rta 12's are hollow and may not support spikes without reinforcement.
That's good to know! I installed the inserts, but have not put the spikes in as I need to build extension platforms for the speakers.
I'll watch for that!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I've desided to build new risers ( solid wood ) and replace the original ones, than I've talked to a local machine shop who can make a set of outrigers for me. 1/4" x 1" steel drilled for mounting and drilled annd taped ( 1/4 - 20 ) for the points. The cost will be aprox. 45.00 per pair plus the cost of the points. May be over kill but I think they will plenty stable and will get then up another inch or so.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
