2 PSW125 or 2 PSW111
bryant_neal
I am going to be purchasing two new subs through my work discount and there is a very minimal price difference between the two models ($70 total), and the cost is very low as well, i have a large living room appoxmitaly 20x20 and was wondering which would be the better set up, thanks.
Post edited by bryant_neal on
I would go with the two PSW-125 Subs. I like the 12" over the 8" and the 12's go a lot lower than the PSW-111's.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
HT???
bigger trumps littler...is that even a word??
go big. try stacked and corner loaded....you should get at least a 6db boost...if you room is a perfect square this can be a problem....by having two subs and placing them in different parts of the room you greatly reduce the chance of having "no bass" in the money seat...so either way two and for HT bigger is better...for musicality not always true.
RT1
