Polk Audio db840 8-inch single voice coil subwoofer speaker-Still the best option?
jmos
jmos Posts: 40
edited December 2011 in Speakers
Post edited by jmos on
    EndersShadow Posts: 17,722
    edited August 2011
    I believe the db840 is still the best one out there. If the Polk Engineering folks recommend it, I'd do it (I did).
    Just keep in mind if you buy from a unauthorized dealer (both those links are) then you get no warranty if something goes wrong (with the sub).
    I went ahead and spent the extra cash and went with Crutchfield. They are running buy 1 get one 1/2 off sale right now. http://www.crutchfield.com/p_107DB840/Polk-Audio-db840.html?search=db840&skipvs=T
    After this mod, your crossovers should be next (or a better amp to drive your LSi's depending on what you have)
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2011
    Yes run that driver as it still is the best option.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • jmos
    jmos Posts: 40
    edited August 2011
    Great, thanks for confirming that.
    Appreciate the buying tips, need to ship to Western Australia so I'll check those options.
    Online prices over here are about $139 but I'll shop around and contact a few stores direct.
    Currently using an Elektra Theatre HD Amp, made over here, made a huge difference over firstly my Onkyo 875, than Nad T973. Here's the specs on my current amp
    http://clefhifi.com.au/catalog/product_info.php?cPath=56&products_id=70
    I didn't pay anywhere near the display price though
    Power per Channel (Watts RMS)
    7 Channel at 8 ohms 190
    7Channel at 6 ohms 225
    Dynamic Power (Watts RMS)
    8 Ohms 200
    4 Ohms 400
    Total Harmonic Distortion THD @1Khz < 0.0003%
    THD <0.001% 20-20Khz
    Frequency Response 3Hz - 250 kHz. +0,-3 dB
    S/N Ratio 111 dB
    Input types: Balanced & RCA
    Single Potted Silent Power Transformer Yes
    Discrete Power Amplifier Circuitry Yes
    Banana Plug Compatible Speaker Connectors Yes
    12V Trigger Yes
    Height 160 mm Width: 445 mm Depth: 370 mm
    Weight 25 kg
    Thanks again
  • teamjhertz
    teamjhertz Posts: 363
    edited August 2011
    There is a really cheap pair of these subwoofers on eBay right now and might be worth a shot.
    I know you are in Australia but I thought someone might be interested.
    The item number is 250875802624
  • TouchOfEvil
    edited August 2011
    I got both my db840's from ebay. have had zero issues.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • ddward
    ddward Posts: 4
    jmos wrote: »
    8 Ohms 200
    4 Ohms 400
    S/N Ratio 111 dB
    12V Trigger Yes
    Weight 25 kg
    Thanks again
    Thats a real nice looking amp. good looking specs:
    Sunfire cinema grand amp, Marantz sr6500 pre/pro, Polk lsi15 mains, Polk lsic center, Polk lsi7 rears,
    Def tech sub. Blue Jeans interconnects.
