Okay to run Monitor 7C's as large, with Yamaha AVR?
HTguru1982
HTguru1982 Posts: 1,066
edited August 2011 in Vintage Speakers
I found an old brochure for these which stated that the 7C's have an impedance of 4 ohms. However after doing about an hour of reading, I found an old thread in which a couple of members mentioned that they were actually 6 ohms. :confused:
If this is case, then would my Yamaha 2500 be able to safely power these if set to large? What would you guys suggest?
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Post edited by HTguru1982 on
    pitdogg2 Posts: 27,725
    edited August 2011
    yes you should be fine, But I see a sub in your signature so why run them as large? just keep an eye on the volume because it your Yammie is like mine(RxV992) even though rated into 4ohms they really don't do well.
  • bluecomet
    bluecomet Posts: 1,118
    edited August 2011
    I don't believe 7C's are 4 ohms. I looked at my original Polk owners manual for Monitor 7's with a peerless tweet and they are 8 ohms. I doubt the newer 7C's had a lower impedence.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
