Speaker
I saw a pair of vintage Polk Rt800 Floor standing in CL for $350. pair. Does anyone know if these are the same as the Rti8 or Rtia5? The spec's seems to be the same.I've been looking at replacing the m70 with RT fronts. I have a desent sub so a7 or a9 might be bass overkill. Thank you in advance for your help.
http://www.polkaudio.com/homeaudio/products/recent/rt800i/?reviews=1
Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Post edited by over50 on
pre-RTi8
for $350 i think you can do better than RT800(i)....Rti8 can be had around $300 plus it will match prefectly with the Center that you already have....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
They are a decent speaker but should be under $200. While they are the same basic set-up as the RTi8 and RTi A5s, the RTi8 and RTi A5s include a number of changes including a different tweeter. Since you already have the CSi A6, I would hold out for a used pair of RTi8s which be a better match for your CSi A6. You should be able to find them used for around $300. -
Thanks for the feedback. After reading the replys i totally agree. ThanksMarantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
BDI Icon 9429 TV Stand -
$350?? :eek: Way over priced imo. I passed on a pair for $75 a while back. Hopefully Scotty snagged them.--Gary--
