checking out a nice sub
leftwinger57
leftwinger57 Posts: 2,917
edited August 2011 in Speakers
Hello again, I came across this add for a Polk SUB-PSW 125 which seems to blow my Klipsch out of the stratisphere.First off my sub has a 8in woofer that is part of the H/T 500 set. knowing that the Polk is12in at 300 watts so powerful if indrodueced itmay blow it out of the water . All along I've been hearng at about timbre matcthing systems but wondered if this included also the subs.I do not intend on getting this sub but knowledge is power and the more info you retain can't hurt.
  • PrazVT
    PrazVT Posts: 1,607
    edited August 2011
    No - I'm pretty sure timbre matching isn't something to worry bout with subwoofers. Timbre matching probably has more to do with the tweeters and midrange - instruments, voices, etc.
    Your choice of sub, though, depends on what you're going to use it for mostly. I have a PSW-505 that is similarly pretty powerful for what it is - and it does well for HT. But I haven't been that enamored with it for music - but could be placement, the room, perhaps tuning. My cousin's Epik Legend, however, disappears in his living room when playing music and is controlled and tight for movies.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    Timbre Match is not an issue for subs.
    Placement is key to a subs performance.
    The PSW-125 is a very basic sub and will only be a bit better than what you have.
    The PSW-505 is a much better sub musically and for HT and is much stronger.
    Watch this video on how to place a sub in a room.
    http://youtu.be/uzCIMufCQLk
