No LFM on RTA12's
Michael8it
I picked these up from the original owner, and based on the dates on the drivers these were made in late 1980.
Based on the schematic (found on this forum):
The LF Module consists of two ??? - I dont know what they are. Diodes? The value shows 6.5, but I dont recognize the symbol.
In any case, my 12's have NO LFM - they are wired directly to both of the drivers from the posts on the back. This does not seem right.... Anyone have any idea as to why it would be this way? And should I install the components shown on this schematic?
I am working on an overhaul of the crossovers, and the bass on these seems a bit muddy, so I am hoping this will tighten things up. I am concerned though about these drivers and no LFM.
thanks,
Mike
thanks,
Mike
Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
Post edited by Michael8it on
That symbol is for for the mid range drivers. The 6.5 refers to their diameter: 6.5 inches.
Polk uses the same one on the schematics for the other versions of the RTA 12's"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Ah...... I get it. Thank you!Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
