Best preamp/amp for RTi A9 ?
Mosu22
Mosu22 Posts: 4
edited August 2011 in Speakers
Hi everybody,
I'm new to this so I was wondering if I could get some advice. I have a pair of RTi A9's for front with RTi A5 for rears and CSi A6 center and Velodyne DLS 5000 run by Yamaha HTR 6290B. I'm trying to find something that would give more power to the A9's...anyone have any sugestions on what preamps/ amps would go well with these speakers? Thanks
Post edited by Mosu22 on
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2011
    Well if power is what you want then it would be an amp you need. I'm not sure I your ave has pre outs but you would need them if you want to add an amp. Then it comes down to budget and how many channels you want to power 2 3 or 5 are the normal ones people will look for if trying to do ht. If you are mostly a music person a good 2 channel amp will add a lot and can run the rest off the avr.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2011
  • Mosu22
    Mosu22 Posts: 4
    edited August 2011
    Hi...lets say up to 3000..give or take:)
  • cstmar01
    edited August 2011
    3k will get you a very very good amp and can easily do a 5 channel and have some left over. For that budget you could even get some mono blocks but once again you need to decide how many channels and if your current avr will work.
  • EJR2
    EJR2 Posts: 5
    edited August 2011
    The course of action depends on room size, your listening level preferences, budget, HD codec desires, and willingness to purchase used or refurbished.
    I made the decision to buy a refurbished NAD T785 to drive a RTI A system. It has pre outs and is 4ohm capable, so if I want to upgrade in the future or drive a nice two channel in another room using another zone, those options are all open. It has been nine months and I am extremely happy with it. It is feature-lite compared to other AVRs out there, but I like that. Others do not.
    There is a ton of advice if you search this forum and others. Once you get a feel for different brands (and the features they have that you want), making a decision gets easier. And go and listen to as many of them that is possible. Its all part of the fun.
  • Mosu22
    Mosu22 Posts: 4
    edited August 2011
    Would like to power all 5 and the receiver will work.(has pre outs). Name what you would go for...just trying to see what people would chose. Would you condider rotel/emotiva/parasound/denon?
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2011
    Almost anything in regards to an actual amplifier. It's an easy speaker to drive @ 90db and no need to spend money like you won the lottery.
  • Mosu22
    Mosu22 Posts: 4
    edited August 2011
    I didnt win the lottery but if im going to invest in something i want it to last and I want clean sound.
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2011
    Used Sunfire TGA-5400. $3300 new, 5 channel, 800W/ch @ 4 ohm.
    I use mine with 4 LSi15s, and a PSB Synchrony One center, and love it for HT, surround SACD, and two-channel. Of course, I have also upgraded the 5 ICs to MIT, and am using Mapleshade Golden Helix Plus speaker wire, and those upgrades helped the sound.
  • angelsfann02
    angelsfann02 Posts: 589
    edited August 2011
    With $3k to play, I would buy a used Parasound hca-2205A, used Rotel RMB-1095, and a new Emotiva XPA-5. Try 'em all, sell the ones you don't love. Besides, all 3 have great resale value right this minute, and the Emo has 30day return. Voila!
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • Outfitter03
    Outfitter03 Posts: 563
    edited August 2011
  • kevon27
    kevon27 Posts: 18
    edited August 2011
    Emotiva, Emotiva, Emotiva.. XPA1 $1000 Monoblock (500w) 8ohms, (1000w) 4 ohms
    Pics:XPA1_angle.pnghttp://emotiva.com/xpa1.shtm
    XPA 5 $900 (5 channel) (200w) 8ohms, (300w) 4ohms
    http://emotiva.com/xpa5.shtm
    Reviews:http://emotiva.com/reviews.shtm
  • Ghistos
    Ghistos Posts: 18
    edited August 2011
    I juste received my Emotiva XPA-2 for my two front (RtiA9) and I have switch my XPA-3 for my surround and my center... AMAZING, AMAZING AMAZING
  • engtaz
    engtaz Posts: 7,669
    edited August 2011
    Congrats on the new toys.
    engtaz
  • jbooker82
    jbooker82 Posts: 1,627
    edited August 2011
    A USED Parasound Halo 200 or 250w x 5 channel. 60 amps per channel
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • jkg123
    jkg123 Posts: 114
    edited August 2011
    Is there a major difference between the Emotiva and other brands?
  • jbooker82
    edited August 2011
    I have just been told that Parasound has a warm sound. It helps knock down the sharp edge on the higs that the RTI A line has. I just got a carver A-753x. Carver amps are supose to have a warm sound as well. My RTI A7's sound pretty sweet with the new power.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
