Question for Monitor 10B upgrade: 2.0 or 2.5 ohms?
Hardrock.ca
Hardrock.ca Posts: 27
edited August 2011 in Vintage Speakers
I saw the parts list is in post
http://www.polkaudio.com/forums/showthread.php?t=117359&highlight=crossover+monitor+10B
2 Mills MRA-12.2.5 ohms
2 Mills MRA-12.2.7 ohms
4 Sonicap 12uF 200VDC
2 Sonicap 34uF 200 VDC
4 Vampire BPHEX binding posts
24ft of Cardas Quad-Eutectis solder
But I only can find a 2.0 ohms on the board and schematic diagram
Anyone can clarify which value should be used, 2.0 or 2.5 ohms
If use 2.5 ohms and why?
Post edited by Hardrock.ca on
    heiney9 Posts: 25,497
    edited August 2011
    If your 10's are fused sometimes the resistor value for the tweeter is slightly lower. Otherwise go with either. @ .5 ohms difference it won't matter.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    I believe you use the 2.5ohms if you are removing the polyswitches. I have never upped the ohms on my resistors even when removing poly's so I would go with 2.0 ohms personally.
  • Hardrock.ca
    edited August 2011
    Thank you all, heiney9 and Joe08867!
    heiney9 wrote: »
    heiney9: Just want double check with you : the high value of that resistor(2.5 ohms) will give me a little more treble?
  • Hardrock.ca
    edited August 2011
    I have ordered 2.0 , 2.5 and 3.0 ohms for test :)
    edited August 2011
    The higher value will sightly pad the tweeter circuit as in give you a bit less treble.
    There ya go, that's the best way to do it. The differences will be subtle but pick the one you like best. No harm in trying them all.
