APC H15 and Adcom 5802
acmf74
acmf74 Posts: 937
edited August 2011 in Electronics
If I would to plug in my amp directly into the APC H15 unit... Would the conditioner be able to supply enough power to it?
Thanks.
Post edited by acmf74 on
  • Evrythngmatters
    Evrythngmatters Posts: 187
    edited August 2011
    The short answer is yes. You would want to plug your amp in in the red outlined outlets. Those two outlets are for devices that draw alot of current. If this is like my Belkin PF40 then the filtering is there that you are looking for but the two outlets do not limit current. Here is a link to the manual btw. http://www.apcmedia.com/salestools/ASTE-6Z7V8X_R0_EN.pdf
    Here is what it says in the manual.
    High Current Filter Outlets provide filtering for your high current
    devices (Subwoofer and Amplifier).
    Everything matters. That is all.
    Money cannot buy happiness, but it sure can buy a bad **** boat to pull up along side it though.
    tonyb Posts: 33,069
    edited August 2011
    I never have or would plug an amp into a power conditioner, thats just me though.
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    acmf74 wrote: »
    Maybe,maybe not.:smile:It would be dependant upon the sensitivity and relative load the speakers present to the amp,as well as the program material and listening level etc.That is a fairly potent amplifier so it's concievable that the PC will limit it's full dynamic power potential if the speakers present a low impedance load ,have low sensitivity and you like to listen at reference levels.
    On the other hand I'm sceptical of any huge sonically benificial results by running the amp through the APC unless your AC line is particularily noisy and the APC is able deal with it effectively.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    I don't think it will be able to supply enough current for that amp personally. If you have nothing else plugged into the APC I think it would still come up short in current.
    heiney9 Posts: 25,421
    edited August 2011
    I have had my Pass Aleph 30 plugged into my H15 no issues. I have also plugged it into the wall. I don't hear a difference between the two set-ups. I don't think you will have a problem with it plugged into the H15 as the outlet is capable of 15A and it actually has a display showing you how much of the total load you are using.
    I have all my gear plus a plasma TV plugged into my H15 and with everything powered up it uses 28% of the available load. If I turn off the Aleph is uses about 15% of the load. Plug in the amp and run a very high volume dynamic passage and see how much draw everything has. People get all bent around the axel about this kind of stuff like their gear is going to draw more current than an outlet can supply. That's very rare.
    Hope that helps.
  • acmf74
    acmf74 Posts: 937
    edited August 2011
    Thanks all.
    I'm going to plug everything in and see what kind of load i will be using.
    (AVR,AMP,TV,CDP,Cable Box)
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2011
    tonyb wrote: »
    I'm also a no power conditioner user when it comes to amps. I've yet to hear a difference and I've owned several.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2011
    I have an APC J-10 & shut it completely down while jamming with a Sunfire Ultimate Receiver. When it booted back up, the screen said to call APC for technical help~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    edited August 2011
    TNRabbit wrote: »
    Sounds like an APC malfunction. Did you ever find out why? What else were you running at the time? As nice as the Sunfire is, I can't believe it could draw so much current consistently to shut that down without there being a defect or several other large draw components on at once.
  • TNRabbit
    edited August 2011
    I was running full 7.1 setup at the time at ear-bleed levels (War of the Worlds). I rebooted & it worked fine. The J-10 is only a 695 watt unit. The H-15 & J-15 are 1000 watt units.
    TNRabbit
    Sunfire TG-IV
    edited August 2011
    TNRabbit wrote: »
    That would make sense my H15 is 1.5kW and I suppose if you had your sub hooked to it as well.
  • acmf74
    acmf74 Posts: 937
    edited August 2011
    I doubt I would hear a difference too..
    My main concern is have pricey equipment w/o and surge protection.
    edited August 2011
    The main reason I like mine is for voltage regulation. With my amp it doesn't matter so much because it will compensate for variable line voltage. But the other components like dvdp, Squeezebox, TV, Dac, etc. It's nice for surges and brown outs, but a direct lightening hit won't be stopped.
    In severe storms I just unplug everything. Last big storm we had (we've had a lot this season) my neighbors tree got hit and I was in my basement because the weather was that bad at the moment and when it hit the tree I could hear it sizzling and I was inside, below ground about 300 feet away.
    Scared the crap out of me!
