Receiver Center Speaker Settings LARGE or small?
Hi Guys,
I just got my new Center CSi-A6 (WOW it's huge speaker monster
Can you please advice how should I configure it in the Receiver setup (Yamaha RX-V565) should it be Large or small?
Also I notice the following in the Receiver setup:
Crossover Freq. 90Hz
Is it the correct configuration?
Shmulik.
Shmulik.
Post edited by salfand on
I'd run it at small and 80hz, that's the general consensus around here.
I think the less expensive Yamaha's only offer a 90hz crossover point if set to small. But what B said. Set to small and let your sub do the rest.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
HTguru1982 wrote: »I think the less expensive Yamaha's only offer a 90hz crossover point if set to small. But what B said. Set to small and let your sub do the rest.
I don't have sub. I have Polk RTi-A7 as front speakers.
If I will set the center as "Large" will it harm the speaker? -
It won't harm the speaker, but you will get better sound if the below 90 Hz is sent to the front speakers (i.e., set the center to small).
I would be careful with the volume level on your AVR since driving those speakers is a lot to ask of it. -
I don't think the AVR is programed to send the remaining lower frequencies from the 90Hz crossover to the front L/R speakers. It should only send those frequencies to the sub which is missing, therefore they will be attenuated from your sound stage until you run a sub.
I have ran my CSi A6 full range (LARGE) without hurting it. However, it made the sound a little muddy and the EQ for the center had to have some bass removed for protection of the speaker.
A sub is recommend for your next purchase.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
Thank you very much.
Even though you have sub you setup the center as Large?
How can I set EQ to the center? -
You should "almost, always run your center setting (SMALL) with 80Hz crossover". It l's a very good rule of thumb.
I tried the full range (LARGE) setting just to see for myself.
You can go into you AVR's settings andd adjust any of your speakers at will. For specific information on you AVR's adjustment. See your owners manual because I have not owned a Yam AVR, thus I can't tell you the proper steps.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Ok. will do that
Thanks a lot. -
I'd run it large.
While I was set at Small I was using half of my LSiC speaker. Large just sounds better IMO. Try it both ways and go with what you like.Do you hear that buzzing noise?
I agree with Monster Jam.
