Vandersteen 2C's-Good Deal?
pietro944
pietro944 Posts: 720
edited August 2011 in Speakers
I saw this FS used at a nearby Hi-Fi shop:
Vandersteen 2C's used including stands filled with shot-$449....Is this a good deal.....Anyone familiar with the Vandy's?
Are they good for 2Ch listening?...How would you compare to LSi7's...thanks,peter
Post edited by pietro944 on
  • DaveHo
    DaveHo Posts: 3,557
    edited August 2011
    Which version 2C? Original 2C's, not a good deal. 2Ci's, that's a fair price, might be a touch high. 2Ce's or 2Ce sigs that's a good price.
  • pietro944
    edited August 2011
    DaveHo wrote: »
    I believe they are 2C's....thankx for your help...peter
  • Timothy Smith
    Timothy Smith Posts: 764
    edited August 2011
    The price sounds high. As a point of comparison I bought a pair of 2C's with stands for $250. Woofers needed new surrounds which cost $80/pair to redo, so my total came to $330 with some labor and running around on my part.
    Most of these 2's will need the foam woofer surrounds replaced unless it has already been done. It is a devil to remove the cloth to inspect the surrounds and very difficult to see thru the cloth with a flashlight.
    I have a set of Vandersteen 1's that I like very much. I thought the metallic tweeter on the 2's sounded a little harsh in comparison (a common problem for me) so I decided to sell the 2's. They guy I sold them to loved them.
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
  • DaveHo
    DaveHo Posts: 3,557
    edited August 2011
    FYI, I believe the original 2C is the only version with foam woofer surrounds.
