attaching dynamat?
soundfreak1
soundfreak1 Posts: 3,414
edited August 2011 in Vintage Speakers
May I assume its a matter of cutting it to size and applying to to outside of the driver baskets? Any more involved than that? And any of you that have done it aprox how much is needed to do a pair of rta 12's not sure how much to order.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • JPSmario
    JPSmario Posts: 142
    edited August 2011
    search the threads for one where a guy (sorry, don't remember his name) photo documented upgrading his SDA 1C's. he shows great detail on how he cut and where he mounted the dynamat to the drivers and PR's.
    Have fun!
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
  • soundfreak1
    edited August 2011
    Realy could use some input here, don't want to under or over buy. Money is going out fast. ( too many projects) need to buy smart. Thanks.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2011
    Buy a whole pair of doors box and you'll have enough for a multitude of projects and mods. I think it's 50-60. C'mon man, just think about 50 1x4" strips for a second....just as a rough way to decide.
    EndersShadow Posts: 17,596
    edited August 2011
  • soundfreak1
    edited August 2011
    Well thanks anyway
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • thsmith
    thsmith Posts: 6,082
    edited August 2011
    Amazon dynamite extreme. I used on the 4 spokes of the basket on the outside and a small amount on the circular part at the top of the spokes. While at it jb weld the magnet and top washer part of the driver. I did it in 3rds. Hope that helps.
  • WGDB
    WGDB Posts: 162
    edited August 2011
    Well thanks anyway
    Yeah, you see it all over this forum these days - some of these old guys with a gazillion posts can be really rude in there responses!
    Pioneer Elite SC-35, Polk RTA (Real Time Array) 12's,
    Polk Monitor 40 surrounds, Polk CSiA4 Center,
    Polk PSW125, Sharp LC-46D62U,
    Panasonic DMP-BD85, Harmony One,
    iMac streaming an Apple TVII, or Squeezebox Touch
    Bedroom Rig~Sony STRDG-920, Polk Monitor 60 fronts, Polk RM6750 Satellites and Sub, Panasonic DMP-BD85
    Rabbit Hole Rig~Yamaha CA1010, Yamaha CT1010, Polk SDA 2A's, Teac A1500 R2R
  • dorokusai
    edited August 2011
    WGDB wrote: »
    I'm sorry that you found a clear answer rude. Measuring the basket ring length/width is not rocket science and there's no need to overthink the entire project. It's sticky, you cut it and stick it to the basket, press it firmly and move on to the next ring.
    A door kit from Dynamat is more than enough, as stated previously, to do an entire set of drivers and more. What more do you want to know? Why is this so difficult? Should I have expounded on the weather of my location, the anticipated political forecast of tomorrow's news or perhaps what excites me in my nether region?
    WGDB - Hopefully you'll drop some wisdom or reflective thoughts instead of disgruntlement in the future. If you're expecting smiley faces and funny emoticons, go elsewhere....it's just data and simply not that exciting to post about.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    dorokusai wrote: »
    The best suggestion for anyone buying Dynamat.
    Well thanks anyway
    WGDB wrote: »
    I don't see how his answer was rude in any way. If you were looking for a freebie you need to state that. If not than the answer he gave is your best solution. You said it yourself you have many projects and this amount of Dynamat will cover future plans as well.
    By the way, the old guys with a gazillion posts are not mind readers and try to be straight with people. If that isn't your cup of tea than maybe this forum isn't for you.
