4 Bass Shaker wiring help
S T R Y K K E R
I have 4-4 ohm Bass Shakers and have ordered the Crown XLS 1000 amp.....I plan on running the amp in bridge mode.....
I just don't undestand how to wire the 4 Shakers so that the amp see's them as 4 ohm
I found a pic on the net ----this seems to be right.....Is this a Parallel/Series wiring?....Will this make the amp see the Shakers as 4 ohm?....just want to make sure before wiring them up!
heres the pic
heres the pic
16' x 12' Man Cave
Onkyo TX-NR1008 9.2 AVR
Polk Monitor 70's--Mains
Polk Monitor CS2--Center
Polk Monitor 30's--L/R Height's & L/R Wide's
Polk Monitor 30's--L/R Side Surround
Polk Monitor 30's--L/R Back Surround
(3)BIC Formula-12--Sub's
(4)Aura Pro Bass Shakers with Crown XLS 1000 amp
Emotiva-XPA-3 AMP for L/C/R
Epson 8100--1080p LCD projector
120" Elite Screen-- High Contrast Gray
Sony BDP-CX960--400 disc BLURAY player
Sony DVP-CX995--400 disc DVD player
XBOX 360 & PS3
XBOX 360 & PS3
Post edited by S T R Y K K E R on
Yes your diagram is correct for what you want to accomplish. You have 2 pairs of 4 ohms shakers in series which brings the circuit up to 8 ohms and then those 2 circuits of 8 ohms are then paparelled bringing the impedance back to 4 ohms.DARE TO SOAR:
Thanks TECHNOKID!
Can't wait to play some Gears 3 & Battlefield 3 & Blurays ......with these Shakers.
The Audiosource amp 100 wasn't getting it done for me.....the Crown XLS1000 is probley overkill but thats what the volume buttons for.....
16' x 12' Man Cave
XBOX 360 & PS3 -
Hey TECHNOKID...........Do I need to run a single + & - wire out of amp.......and then Daisy chain to each shaker OR run 2 wires each out + & - out of amp to each individual shaker?
This is were I get confused...sorry for so many questions.
Or does it matter if I daisy chain out of amp or individually run to each shaker from amp?
Seems to be the same to me......maybe its not though.16' x 12' Man Cave
XBOX 360 & PS3 -
Yes, this is the easiest and cheapest way. Just get one cable of the receiver and then daisy chain the shakers from there just as per your above diagram.Do I need to run a single + & - wire out of amp.......and then Daisy chain to each shakerDARE TO SOAR:
You know derren, you should go back to SPAM school! 3 SPAM posts within the same thread? You are an easy SPAM mouse to chase by the mods SPAM killers! You have been reported for extermination!DARE TO SOAR:
i know...OLD THREAD.
how did you like the end result of the Bass shakers? im thinking about getting some.mole'
