2.3 tweeter question
BrettT1
BrettT1 Posts: 560
edited August 2011 in Vintage Speakers
I picked up a pair of original 2.3s with the donut drivers. Why does the bottom tweeter look different than the others? I checked the compendium, but unless I missed it, they all appear to be sl2000s.
Thanks.
Brett
Post edited by BrettT1 on
  • BrettT1
    BrettT1 Posts: 560
    edited August 2011
    Just noticed I cracked 500 posts. Damn, it only took 6+ years. ;)
  • headrott
    headrott Posts: 5,496
    edited August 2011
    Are they all original tweeters? (Kind of an obvious question I know, but....) Were any replaced with RDO-194's? A picture would help.
    Greg
  • BrettT1
    BrettT1 Posts: 560
    edited August 2011
    No replacements that I know of. Definitely not RDOs. Here are the RDOs in my 1.2TLs and 1Cs. Here's a pic of the bottom two tweets on these donut 2.3s I recently picked up.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,186
    edited August 2011
    They're SL2000's
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 50,762
    edited August 2011
    Yeah, that bottom tweeter does not look healthy.
  • headrott
    edited August 2011
    Yes they are SL2000's. If I remember correctly the 2000's can age differently resulting in the different way the 2 look. That is, the silver coils age differently resulting in the different looks they have. Others probably know more than I though and will hopefully give their input.
    Greg
    Edit: Jesse beat me to it, so go by what he says.:wink:
  • BrettT1
    BrettT1 Posts: 560
    edited August 2011
    I'm referring to tweeters cover. It's a smaller dome than the others above it. The bottom tweeters on both speakers look identical. ?
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    The bottom tweeters were driven to hard and are melted. If they work I am amazed but they are SL2000's and are a mess to say the least.
    Had an SL1000 do the same thing way back when. I didn't realize i was driving it to hard with to little of an amp.
  • BrettT1
    BrettT1 Posts: 560
    edited August 2011
    I did the high tech paper towel roll test and yes, the bottom tweeters are fried on both of them. What seemed weird was both of them looked factory made.
    Ordering some RD0s.
    Thanks guys.
    Brett
    F1nut Posts: 50,762
    edited August 2011
    They are factory made, no one said otherwise. This is what haapened, the previous owner cooked them, took them out of the top (full range) position, put them in the bottom (limited range) so that the loss would not be as noticeable.
  • Joe08867
    edited August 2011
    That's probably exactly what happened.:cool:
