Klipsch KLF-20's (black)
jephdood
$750. local pickup in Auburn, WA. They're huge. Cannot ship.
Excellent condition. They are about as perfect as you'll find out there.
I put up a few pics on Flickr.. hopefully they're available to all: http://www.flickr.com/photos/96273981@N00/sets/72157627413902554/with/6034127929/
If you're looking at this, you're probably already aware of what the KLF-20's are all about, but here are the specs anyway.
■CROSSOVER FREQUENCY: HF 7,000 Hz, LF 750 Hz
■DIMENSIONS: 40.75" (103.51cm) x 12" (30.48cm) x 16" (40.64cm)
■ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
■ENCLOSURE TYPE: Bass reflex via dual rear-mounted ports
■FINISHES: Light Oak, Medium Oak, Mahogany, Black Satin
■FREQUENCY RESPONSE: 34Hz-20kHz(+-)3dB
■HIGH FREQUENCY HORN: 90(o)x40(o) Exponential Horn
■MID FREQUENCY HORN: 90(o)x60(o) Tractrix(r) Horn
■MIDRANGE: K-52 1.5" (3.81cm) Polymer diaphragm compression driver
■NOMINAL IMPEDANCE: 8 ohms
■POWER HANDLING: 200 watts maximum continuous (800 watts peak)
■SENSITIVITY: 100dB @ 1watt/1meter
■TWEETER: K-79-K 1" (2.54cm) Polymer diaphragm compression driver
■WEIGHT: 86.5 lbs. (39.27kg)
■WOOFER: Two K-1036-K 10" (25.4cm) Poly Carbon Graphite cones
Thanks for looking. PM me with any questions you might have, or to set up a time to have a look/listen.
"I did not slap you. I high-fived your face."
Post edited by jephdood on
Price check! $650 for the pr."I did not slap you. I high-fived your face."
Good luck on the sale; those are kick-****$ speakers. They're d@mned efficient & will pound your kidneys into mush~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
What's that? I can't hear you.
Thanks man.. yeah, they are great. I just have WAY too many speakers in the house right now, and some things need to find new homes."I did not slap you. I high-fived your face."
