Crown DC-300A
EndersShadow
EndersShadow Posts: 17,704
edited August 2011 in Electronics
Is this a decent 2 channel amp? Its pretty old and looks like its got some decent power specs......
Looks to be 175 wpc @ 8 ohm, 305 @ 4.........
http://www.crownaudio.com/pdf/legacy/dc300a2.pdf
http://www.broadcastbaron.com/infocrowndc300a.htm
Also would this be an amp that I could use for SDA's......
Post edited by EndersShadow on
    edited August 2011
    morning bump.....
  • Cayuga
    Cayuga Posts: 480
    edited August 2011
    Depends on what your looking for, its 180 watts and has a bluebook value around $250.
    edited August 2011
    Cayuga wrote: »
    Thanks, means the seller has it over valued by a bit.
    Was curious if anyone had any experience with it.
    Thinking about it as my amp for my dedicated 2 channel upstairs in the office. Right now its running Monitor 60's but eventually I am thinking Carver Amazings, Carver AL-III's or some LSi's....
    So 4 ohm ratings are decent on this guy and it looks like some folks say it can handle loads below 4 ohm....
    heiney9 Posts: 25,440
    edited August 2011
    I wouldn't expect it to sound as good as a decent home amp. In general pro amps aren't designed with musicality in mind. I'm sure now that I've said this 10 people will come out of the wood work and claim it's as good or better than anything out there. (you know the people I'm talking about)
    There are so many better choices than to use a pro-audio amp in a 2 channel rig. If it was free, that might be a different story. I say move on and look at something more musical. This is a popular amp for dj's, etc.......you can't find anything on the 'net about it?
    edited August 2011
    heiney9 wrote: »
    I found a little bit on the web, but didnt spend a massive amount of time there. Just because info is on the web about it doesnt mean its accurate or trustable (gotta know and trust the source). Hell according to the web Elvis was abducted by aliens.
    I read spec's and whatnot on the web and occasionally reviews, but here when the usuals here chime in with advice, they have a track record with me and there are some whose opinions I value and others (who remain nameless) I ignore :smile:. Plus normally you guys have all the info I need anyway.
    So this forum is to an extent my fact checker/somewhat trusted source :wink:.
    I thought Crown made some non pro audio gear and that this was one of those pieces. Didnt have the usual fans that tend to let me know that.
    Will keep looking.
    edited August 2011
    AFAICT, they were used in sound reinforcement in the 70's and 80's. Don't think it's a home unit and it may even have a fan. I know Jinjuku had a few of these and thought they were the crown jewel (pun intended). Not sure what value you give to his opinion.
    edited August 2011
    heiney9 wrote: »
    LOL..... no comment.
    It doesnt have a fan, its just got funky fins sticking out the back.
    Looked intriguing, but the price is waaayyyy out of line.
    edited August 2011
    I heard one a long time ago as a green audio salesman. The one my buddy had had some static issues and of course back then I didn't know what I know now or have that much experience behind me as far as critical listening.
    I just think you could do better, especially since this if for a 2 channel rig.
  • JPSmario
    JPSmario Posts: 142
    edited August 2011
    I've had my DC300A for 20 years or so. it lives in a rack in storage right now because I'm not playing professionally any more.
    Pro-audio is what is was designed for. while you saw them in some home audio shops back in the 70's, I think they carried them primarily due to it being the most reliable amp out there with that kind of power (180 watts/ch into 8 ohms was a LOT of power in the mid 70's). Phase Linear had amps in this power class back then, but they had a tempermental rep for blowing up. Crown DC300's were much harder to kill. I attended a Herbie Hancock-Headhunters/Return to Forever concert where they ran these amps with 2 ohm loads (they had to have 20 in. fans on the back of their power racks to keep the thermal protection circuit from shutting them down:biggrin:)
    In terms of pro-audio, it was clean and quiet in it's time, but mine is in storage because it can't play in the same ball park as my Rotel. In comparison, the Crown may have a little more punch, but it's noticeably noisier and grainier.
    I hope this helps.
    Jim
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
  • thsmith
    thsmith Posts: 6,082
    edited August 2011
    mhardy6647 Posts: 35,041
    edited August 2011
    The old Crown solid state amps are well-built, bullet-proof, rugged and sound just awful. Their contemporary ss preamps sounded even worse.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    +1.
    It is made for sound reinforcement and not audiophile sound.
    edited August 2011
    Well, there are good sounding commercial/sound reinforcement amps, too (even today!).
    ... and the Crown pre- and power-amps of that era found there way into lots of home hifis.
