dynamat?
soundfreak1
soundfreak1 Posts: 3,414
edited August 2011 in Vintage Speakers
I have read a lot of comments about dynamat on the baskets of drivers, what does it do? And the advantages? Like to learn about this. Thanks in advance. I using rta 12b and c speakers.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • Outfitter03
    Outfitter03 Posts: 563
    edited August 2011
    Dampens vibration or ringing of the baskets.
  • soundfreak1
    edited August 2011
    My ears ring sometimes, I even where a ring once in awhile, but never heard my speakers ring. Is it common with some polks?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited August 2011
    In all seriousness getting set up to do a mod on a pair of rta 12b or 12c's and have been studding a lot of threads on the subject and I get the vibration aspect for its use just.haven't hears the problem myself and wonder if its me. Darn speakers seem pretty nice to me as they are. But I know the cap age, and they can make a huge diff. When updated. Just trying to learn as much as i can before i start. Thanks
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • brgman
    brgman Posts: 2,859
    edited August 2011
    Get Dynamat Xtreme off of amazon and put it on like you see here on the forum.Lots of pics.While you're at it put JB Weld or Loctite Metal magic Steel on the magnets to prevent shifting.
    You will like what you hear.
    2 million polkies can't be wrong!
    I’M OFFENDED!!!!
  • soundfreak1
    edited August 2011
    Well that was the point of my thread. I figured there had to be something to it. Can't hurt and whilst I have them torn apart might as well. If I end up doing the c's they already have the rdo 194's in them. Also need to learn about the insolation marerial stuffed inside the cabs. The cabs are tight no major air leaks. So I guess its caps and maybe wiring. Poss. Binding posts and bottom xovers. As well.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • brgman
    brgman Posts: 2,859
    edited August 2011
    Have fun!!!
    I’M OFFENDED!!!!
  • Outfitter03
    edited August 2011
    Ever play the Triangle in Grade School, same concept! From Wikepedia:
    Audio
    Ringing affects audio equipment in two ways. Audio electronics have the same ringing issues as do all electronic equipment, with the exception that the ringing may be audible. In addition, transducers (ie, microphones and loudspeakers) can also ring. Arguably, mechanical ringing is more of a problem with loudspeakers as the moving masses are larger and less easily damped. Mechanical ringing, unless extreme is difficult to audibly identify as such. It is usually noted as a like of characteristic 'coloration' in the sound and is very hard to describe in words.
  • soundfreak1
    edited August 2011
    That makes it more clear to me, I have expierenced that in some previous electroncis I had but had never atributed it to the speakers per say, as a vibration. I have always refered to it as a resonance or artifactics. That helps me get my head around it better. Thanks.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • JPSmario
    JPSmario Posts: 142
    edited August 2011
    when I dynamatted and mortited my SDA 2A's (did both at once, so I can't comment on effects of these mod's separately), my mid range seemed to open up and quiet down- more 'blackness' or space between instruments. the bass now seems to well up from the floor. I love the changes.
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
  • soundfreak1
    edited August 2011
    Ok jp just got a handle on dynamat and then you start with mortite! Ok I' ll bite. Wtf is mortite? It's always something.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 52,005
    edited August 2011
    The thing about tweaks is that they are additive. That is each one on its own may not make that much of a difference. However, the sum total results in noticeable improvements.
    Mortite is a caulk sealer designed to be used around the home. Some folks have replaced the stock driver gaskets with it and reported good results, while others did not like the results. I believe that if the stocks gaskets are in good shape, there is no need to use Mortite. I'd suggest you do plenty of research before going down that road as there are tricks to using it properly.
  • fbm211
    fbm211 Posts: 1,488
    edited August 2011
    Skip the mortite.
    Dont skip the dynamat extreme.It will amaze you at how much better sounding the mids are after the tweak.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • soundfreak1
    edited August 2011
    Got it. The cabs do seem quite air tight as far as the compression test with the passive wooded. The gaskets seem good so far. Once I get the two drivers replaced than the caps are next. Oh boy . Got to figure what brands to choose. ?????.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 52,005
    edited August 2011
    If you can, get a set of Larry's rings.
  • soundfreak1
    edited August 2011
    I read about those here but if the cabs are tight , is there any need? Or do I misunderstand there purpose.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 52,005
    edited August 2011
    Yes, there is a need. The rings couple the drivers to the cabinet better than the stock screws and completely negate any concern about the gaskets. The sonic results from installing the rings is not subtle.
  • soundfreak1
    edited August 2011
    Ok. About how much dynamat does it take to do the 2 driver baskets and i suppose the passive as well ( per cab.) And what does Larry sell the rimgs for when he has tthem aprox. Just budgeting.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 52,005
    edited August 2011
    Not much.
    Larry has a thread in the FS section.
  • JPSmario
    JPSmario Posts: 142
    edited August 2011
    OK, I'll bite. what is the sonic difference you hear between mortite and Larry's rings?
  • DON73
    DON73 Posts: 516
    edited August 2011
    I'm sittin here right now looking at the silver backing on a box of dynamite I got from Amazon. Tried it on my ears but they still ring. I'm hoping that it does better when I do my 10s. The stuff is hard to get off so make sure you want it where you put it!
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
