need a taller speaker stand for Lsi9s (at least 32")
Norm Apter
Norm Apter Posts: 1,036
edited August 2011 in Speakers
I've scoured many of the threads on speaker stand recommendations for Lsi9s, but am having difficulty finding specific references to taller ones. Given the tweeter/woofer configuration of Lsi9s combined with my height (6'2") and listening position, I need something a bit taller than the standard 26-" or 28"-height stands to get the tweeters at ear level.
I've seen many references to brands such as Target, Skylan, VTI and Sanus as being good ones for Lsi9s, but when I've done some background searches I've had difficulty finding anything taller than 28" -- I'd be happy to go with any of these brands or others but I'm wondering if anybody has any specific model-based recs for taller stands that have top plates large enough for securing the rectangular-shaped base of Lsis.
Budget: I'm hoping to find something for $300 or under but would consider higher-priced items if nothing at that price point can meet my needs.
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    just take a look on racksandstands.com. My VTI stands are 30". Not the prettiest things in the world, but filled w/ sand they are solid.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  • Timothy Smith
    Timothy Smith Posts: 764
    edited August 2011
    Bell'0 makes a 36" tall steel stand sold by Racks and Stands
    List price is $251/pair, currently on sale for $99.99.
    The specs say capacity is up to 100 lbs. and the top plate is 7" x 7".
    I have a set of these and they are very sturdy and might work for you, especially if you add something to make the base wider.
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
  • Tbone289
    Tbone289 Posts: 661
    edited August 2011
    I like these for the price:
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-806
    You can get them in 30" too. But honestly, if I could afford LSi-9s, I would probably go for something of higher quality.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited August 2011
    Norm,
    Have you tried the Mapleshade 'tweak' of putting the LSi9s on a low floor level type stand and angling them 'up' to your listening spot?
    Just saying it might be something to try.
    Erik
  • Tbone289
    Tbone289 Posts: 661
    edited August 2011
    Erik Tracy wrote: »
    Norm,
    Erik
    That's a good suggestion. My RT7's were about 3" too low, and I tilted them back about 10 degrees. It worked well.
  • Norm Apter
    edited August 2011
    Thanks for the suggestions so far.
    A quick follow-up on top-plate sizes....most of those I've seen measure somewhere in the vicinity of 6" x 6" or 7" x 7". Not that i would expect to find anything close to the size of the Lsi9's base (about 8" x 15"), but would top plates in the 6-7" squared range work OK with these speakers?
    2 Ch.
    HT
    Denon 2808ci AVR
  • Norm Apter
    edited August 2011
    Erik Tracy wrote: »
    Norm,
    Erik
    That is a good idea. The problem is that I'm in the middle of a move right now and have no speaker stands with which to experiment (I had them sitting on some metal shelving that I picked up Target, but disposed of that during our move).
    Anyway, if I have to go with something a bit shorter, I'll definitely give that a try.
    2 Ch.
    HT
    Denon 2808ci AVR
  • Norm Apter
    edited August 2011
    PrazVT wrote: »
    Good thinking. I just did this and found this pair.
    http://www.racksandstands.com/Transdeco-International-TD32B-TDI1047.html
    Never heard of Transdeco, but it looks like the color would be a nice match for piano-black Lsi9s (the ones I have).
    I also e-mailed Skylan to see about tailoring the height and top plate size of their SM-26 stands. I'm still waiting for a reply from them.
    2 Ch.
    HT
    Denon 2808ci AVR
  • madmax
    madmax Posts: 12,434
    edited August 2011
    Needing an additional 4 inches or so have you looked into some thick heavy granite blocks or such to spike into? That could be a classy solution.
    Vinyl, the final frontier...
    F1nut Posts: 50,762
    edited August 2011
    Sanus Ultimate stands are excellent, come in 30" and 34" heights. You can find them for under $300.00 if you look around.
    Skylan stands are also excellent. If you ask Noel nicely (call him), he'll probably make you a pair up to 36" (including 1" spikes) for an upcharge and a little extra for shipping.
    Absolutely.
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2011
    Erik Tracy wrote: »
    Norm,
    http://shop.mapleshadestore.com/Stands-For-Small-Speakers/departments/61/
    The best stand is to swap them out for LSi15s.
