Im ready to buy but can't make a decision.
1QWK510
1QWK510 Posts: 19
edited August 2011 in Speakers
I have it narrowed down to either tl250 5.0 , polk tsi100 cs10 setup, or possible rti a1's if its worth the upgrade. System is will be used primarily for tv/movies , with a little gaming any very little music. Speakers need to be wall mount. I like to keep speakers small as possible for WAF, but she has ok'd small bookshelfs if it is a noticeable performance upgrade. Will he using a denon 1712 or 2112. Thanks for any recommendations . Also what would you recommend for surrounds if I go with the rti a1's? I can put the surrounds on stands if needed. Room is roughly 12x25.
Post edited by 1QWK510 on
    Toolfan66 Posts: 17,338
    edited August 2011
    You could use RTiA1's all around if you wanted WITH A CSiA4 for the center, would be a nice little set up IMO..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    I have RTi A1s as surrounds - I could see them working all around too. Great little speaker.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  • 1QWK510
    1QWK510 Posts: 19
    edited August 2011
    So I take it you guys think the $160 upgrade to the rti a1 and csi a4 center is worth it over the tsi100 and tl 250's . Anyone using them with the keyhole mounts. How do they sound. When I get home ill post some pictures . I'm just not to sure on placement. Thanks for the quick replies.
