Tsi400 vs TRi A7
tiberius1023
tiberius1023 Posts: 9
edited August 2011 in Speakers
I'm having trouble deciding between the Tsi400s and the TRi A7s. I've heard the 400s in person so I know what they sound like. There's a pretty big price difference between the 2. Are the A7's worth the additional cost?
Post edited by tiberius1023 on
    tonyb Posts: 33,071
    edited August 2011
    In short....yes. The A7's will require alittle more juice to sound their best than the 400's though so take that into consideration.
  • tiberius1023
    edited August 2011
    What receiver would you recommend? Right now I have an onkyo 606....runs really hot...wouldn't mind replacing it.
    nooshinjohn Posts: 25,904
    edited August 2011
    I don't see pre-outs for the mains on the Onk, otherwise I would suggest just getting an external amp for them. I would look for a reciever with pre-outs for all channels if possible, and one that had all the features you want for your setup. Pioneer makes some nice stuff, as does Denon, Onkyo and the higher end Yamahas. I have no experience with the RTi's but I can say my mid-level Yami and the Moniotor 50's I had were very bright sounding. RTi's are a bit better in that regards but others still say the pairing with Yamha can be a tad on the bright side.
  • PrazVT
    PrazVT Posts: 1,607
    edited August 2011
    On the Yamaha front, I think someone mentioned recently that the new RX-A series AVRs were not as bright as the RX-V series. Op may want to google a bit on that to verify - otherwise, the new Yamahas look pretty attractive as well. And they tend to include pre-outs at a lower price point.
    I love my Denon, but pre-outs are only included in the 331x models and higher, which start at over $1k. Onkyo and Pioneer tend to include pre-outs at a lower price point as well.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
