Help With New 8 SDI Speakers
MSeeb
MSeeb Posts: 1
edited August 2011 in Speakers
Just installed two 8 SDI outdoor speakers using 4 conductor 14 gauge wire to each. farthest run is 50 feet. Trying to power from my Denon AVR-2105 receiver. Can barely get any sound out of them. What sound is present is very tinny (high) sound. The receiver is rated at 90 W per channel. Is the receiver just to small? Any ideas?
Post edited by MSeeb on
  • larry777
    larry777 Posts: 480
    edited August 2011
    Is your Receiver set for 2 channel ? Did you attach the speaker wire correctly ? Make sure the same side of the wire attached to the positive post from your Receiver is also attached to the Positive post on your speakers and the same for the Negative. If you have a muting setting on the Receiver make sure that it is turned off.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
    txcoastal1 Posts: 13,338
    edited August 2011
    What fasteners did you use on your cables, you may have a pinch causing a short
    Have you tried only on speaker at a time then swap the chnls
