Cs2 Center channel issue
I recently purchased the Polk CS2, Monitor 70's, and monitor 30's, all hooked up to a very basic sony dh810 receiver. My issue is i did a calibration, and when i played a movie the center channel seemed to be very quiet. I then went into the Level and saw it had set it to -3.0. I turned it to +2.0 and it sounded better but the monitor 70's seem to drown it out. What can i do to make the dialogue sound better?
Post edited by Bdyllius on
Your best bet is to get yourself an SPL meter to calibrate your speakers. If not i would definitely turn up the level on the center til you hear it blend better with the 70's. I have owned a cs2 and they sound pretty good once you have it dailed in right. those built in calibration systems usually never work to good. Good luck.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
Could it be what your listening to. Some movies have a very dynamic front stage meant to be played at bight volume.
Some people adjust the center channel level instead of turning the master volume which would make everything louder.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
Thank you for your responses.
And?........ Figure anything out?65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I have an Onkyo that will set my CS2 a little under my 70's. I just do the same thing you did, just bring up the center a little until I'm satisfied with the sound.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
I did the same thing on mine too and it worked. I actually had to take it up to a +7. Sounds good now.
tiberius1023 wrote: »I did the same thing on mine too and it worked. I actually had to take it up to a +7. Sounds good now.
That does work but with an SPL meter you can calibrate all your speakers to the same level. You can find them online for about 20 bucks on up. Great little tool to have for HT.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
I got an SPL meter for this reason but have mixed opinions about it. It worked alright for the front sound stage... it's excellent there. All of them are dialed in well and blend seamlessly.
I cannot dial in the rear speakers correctly with the SPL meter. When I start adjusting the volume level on the rear speakers, they sound WAY louder than any of the front stage speakers before they even get close to reference level, according to the SPL meter.
I'm not sure why I can't dial in the rear surrounds, but I've had to just do the rear speakers by ear. Since 60% of my home theater use is for gaming, it's a big deal that I get my surround speakers sounding as equal as I can to each other in volume level. If the back set are louder than the rest it throws off the immersion.AVR: Onkyo TX-NR808
Amp: Emotiva XPA-5 200 watts x 5
Fronts: Polk Monitor 70 Series II
Center: Polk CS2 Series II
Surrounds: Polk Monitor 70 Series II
Sub: HSU VTF-2 MK4
HDTV: 73" Mitsubishi DLP-73740 3D-ready
PS3, 2x XBOX 360, Wii U, Gaming PC. -
Also bumping up the frequency on the center channel cleans up the dialog. If autocalibration sets it to something below 80hz, try 80 or higher on the center ch and see how you like that. Worked for me ;-)Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
