diy sub/tv stand
sophie
I'm going to build a sub enclosure to use as a stand for a 42" tv and my m5jr's. I am thinking of using 2 dayton 15" Reference HF drivers from PE, one on the left side and one on the right side. the enclosure is going to be 14-18 ft^3 with a port tuned to 23hz. to keep the weight down i'm planning on single 3/4" mdf sides with bracing every 8". Does anyone have concerns about the enclosure being to weak or putting electronics on top of this?
I don't know what im powering these with yet...thinking about a crown xls1000 or two 500W bash plates. any input?
can someone tell me how to figure out what port size or how many I need using winisd?
Thanks,
Payton
Thanks,
Payton
Polk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT
Adcom gtp 400
Adcom gcp 600
Thanks,
Payton
That size sounds right (7-9 cu per driver) but I think it would be better sealed usually porting sounds good at one are but not so good at the others , I built a 5 cubic ported tuned at 23 hz it was a failure ,Than I went sealed at 8 cubic feet and got that from winisd , I am using a dayton single quatro 15" and a parts express sa220 plate amp .
You can try isoberic clamshell design , my mtx 12 (2 of them) goes lower than my 15" I get 109 db at 20 hz w/300 watts . Dont try a crown XLS 402 I just sold two it wont push the sub under 25 hz .
Why are you going ported ?
I am willing to bet if you sealed 7-9 cu you will get a better sounding bass and you wont need a monster amp , on winisd it shows curves power in vs db output and at what frequency , with that you can see how much power you need , maybe winisdpro will be easier .
I dont think it will be wak but I would br concerned about magnetics plus early failure shaking the tv plus it way produce a unclear picture during the deep bass you will have to isolate the tv's base . -
not sure what you are saying in your first sentence but here is a winisd screenshot of my 3 options, all in 15 ft^3 with 2 drivers. the ported subs seem to have a flatter output and higher spl than sealed. what do you think the advantage of a sealed design would be?
PaytonPolk monitor 10B's and 5 jr's
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
I see less spl in the sealed but a smoother curve (less hump) than the sealed , I cant read your graphs what driver is that for ??
Its possible a ported cabinet will have more spl but my past experiance with all ported home subs just gave me not that nice a sound , wont you get a smoother curve but will need more power ?
Your graph shows 15 cu feet with one driver I thought the plan was 14-18 for 2 drivers , when 2 drivers are in a box (except isoberic) the drivers share the volume so thats 7-9 cu per driver .
Also I think you are using one enclosure so remember 2 ports will act differantly so a single port is better .
Why not build 2 boxes one for each 15 and make each a stand ?
Also how much power did your graph say it needed ?
it may be there but no matter how much zoom I try cant see it .
at 20 hz its like 5 db differance , a buddy of mine runs 4 of the hf 15" with a adcom multi ch its like 250x5 wpc if you pm me your email address I will have him write you . -
the 2 drivers have 950 and 975 watts for the ported enclosures. this is modeled with 2 drivers per enclosure, it just isn't shown in the screen shots.
this is not for any critical music listening, this is going to be shared between me and my 2 roommates and will be used mostly for tv, movies, and xbox. what if i made it ported and then plugged the ports when i wanted t sealed sound? this is going to be in our 12*17 living room that is open to a ~13*13 kitchen so it is not in a small theater room.
Adcom gtp 400
Adcom gcp 600
http://www.the12volt.com/caraudio/boxes.asp
http://www.decware.com/newsite/diy/decware/Plans.html
http://www.mobileinformationlabs.com/HowTo-1Woofer-Box-CAL%20Port%20lenth%201.htm
I wouldn't set any electronics on any sub period. Why not make it into a coffee table instead of a tv stand?
I have a homemade in an 18x30 room with (1)15"/500wrms in a 4.15'^3 dual 4 inch ported enclosure. When its bumpin its like talking into a fan.
I know I'm about to get the book thrown at me but in my opinion the flatness isn't nearly as critical when your talking movies and video games as its usually the boom your after not the musical accuracy. MY.02...
Good luck at any rate. Subs are an infinite source of adjustability and entertainment. Have fun!
1CToo much **** to list.... -
Payton
thats a good option .
My setup is like yours my living room opens to other rooms I get this louder bass rummbling down the hall , out of curiosity on winisd can you try differant powers ?
Your sub has a 2.5" voice coil I dont think you can put 1000 watts into it safely .
I still have a 5" port laying around I should try that in my 8 cu box .. -
I talked to my friend w/4 of them .
He mentioned going from 10 to 15 cu only adds 2 db at 20 hz be lucky if you notice it .
He ran it at 15 cubic feet and found that 100 watts (each) will get the drivers to exceed xmax (bottom out) .
He mentioned
http
/audio.claub.net/software.kougaard/ubmodel.html
its kristian Ougaard's unibox spread sheet if he has excel .
have fun -
what kind of enclosure is he using? I don't see how he bottomed out the drivers with 100w unless he was below the tuning frequency or using a sealed enclosure without a high pass...
Adcom gtp 400
Adcom gcp 600
Payton
On yours I think he ran the graph ported w/out any subsonic filter, that driver has a 2.5" voice coil and is kinda effeciant ,when the box is bigger it will have less rear resistance on the cone so it can exert very easily so w/out a filter low bass will kill it .
He uses a adcom ?7500? its 225x5 WPC w/like 4 db headroom it has plenty of power he uses one channel for each 15" his box is sealed , I think his are like 3 cubic each he uses a audessy to tune it .
W/out the audessy he would probebly need to go bigger and four of them each being bigger wife would really be unhappy . -
read the parts express reviews & call their tech support , you wil notice the bigger the box the less amp is needed one guy drivs his w/220 watts the the last guy on the first page uses 1 bash 500 for each (he has 2) only runs the amps at 1/3 power .
1C
Agreed 1000 times over about electronics on the sub. I would go with a table top on it and do a wall-mount for your TV.
I also agree about accuracy not being so necessary with movies and games. It's that ultra low thunder and boom that you're typically going for.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
