Flooring Accoustics
tommyt21
tommyt21 Posts: 685
edited August 2011 in Speakers
How much of a diffrence does carpet, tile or wood floor make to the overall sound quality?:confused:
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Post edited by tommyt21 on
  • Gadabout
    Gadabout Posts: 1,072
    edited August 2011
    I bought a new house about 3 years ago and I was asking the same question. The folks that I bought the house from were nice enough to let me set up my HT mains, center and sub in one of the models that was the same floor plan as mine.
    Their model had wood floors, and thats what I was considering installing in mine. The model was also fully furnished, drapes and everything. The wood floors seemed to make the sound bounce around a bit. It seemed to make the sound stage a bit blurred. Was this my imagination or was it real? I'm not sure.
    Anyway, I went with Carpet in the great room, not because I preferred it but mainly for the acoustics. That being said I found that I didn't care for the sub response on carpet and now it's sitting on 16 x 16 piece of tile. I'm sure if I was married, acoustics wouldn't have been factored into the decision of wood floors vs. carpet.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2011
    Gadabout, I see you're running a downfiring sub, so having a harder surface under it is beneficial:) I have to ask Tommy, this is on the bottom floor with a concrete slab?
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    There's a reason musicians have big, cheap throw rugs on stage in front of their monitors, it usually makes a more balanced sound. My entire home is saltillo tile, very bright. A big, cheap throw rug in front of the ML's works great for me, way better bass responce, and it evens out the 'coming from everywhere' mids and highs from the 'stats.
    I might get a better sound with some wall treatments, but I'm happy with the sound now, so why muck with it? BTW, I have a pine plank ceiling, which only adds to the great warm tone I like :smile:
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • tommyt21
    tommyt21 Posts: 685
    edited August 2011
    Polkie2009 wrote: »
    Yes, bottom living room floor is currently carpeted on a concrete slab. We are looking redoing the floor.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • Gadabout
    edited August 2011
    Polkie2009 wrote: »
    Yes, I'm running the DSW 500 pro. Placing the tile under the sub seemed to crisp things up a bit, not quite as subdued as it sounded on carpet alone. The carpet in the house is a pretty low pile, with a good 3/4 in pad, on a concrete slab.
    The other reason I decided to with carpet was the houses on my block are pretty close together. Only 10ft separate houses on either side. Since I'm a night owl, I didn't want to have unhappy neighbors at 2am in the morning cause I'm watching an action movie with the volume up.
    Bottom line, whatever you decide to go with. There are ways to compensate for it. As mentioned above a nice thick area rug, wall treatments, even thicker draperies or adding a piece of tile under the sub as I did.
    Scott
  • Polkie2009
    edited August 2011
    Excellent points Stuwee, the rugs work great to tame those hard floors. +1 on the pine plank ceiling:) Is it any coincidence you see different kinds of wood used in recording studios? Tommy, since you're running a HT setup and have the sidefiring sub, maybe carpeting is best. I do notice a lot of folks with 2 channel setups like the hardwood floors equipped of course with the larger throw rug and acoustic treatments etc...
  • kevhed72
    kevhed72 Posts: 5,146
    edited August 2011
    Every room is different....I went from carpeting and drywall ceiling to hardwood laminate and drop ceiling. I actually prefer the later...
  • gdb
    gdb Posts: 6,012
    edited August 2011
    stuwee wrote: »
    Just hang a couple of kachina & Kokopelli dolls for your wall treatments.:wink:
    VR3 Posts: 29,435
    edited August 2011
    But me down for hard wood floor + rug camp :)
    Hate carpet on every level, acoustics dont even matter...
    If you dont hate carpet you obviously have never ripped some of it up after 10 years to see what is under it ;)
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    gdb wrote: »
    I do have the Bali Goddess Cumon Iwannalayu guarding the ML alcove, note Rockin' Rod and Gayle Sanders on the back wall for back up :biggrin:
  • gdb
    gdb Posts: 6,012
    edited August 2011
    That's not very Tucson of you...... but very cool nonetheless!:cool:
