Monitor 10's
xjghost
xjghost Posts: 1,105
edited April 2013 in Vintage Speakers
I ahve a set of 10's I bought years ago. They are sounding strange lately and need some r and r. I think one of the tweeters is dead. Is there a post around or can someone tell me how to test them? I don't use them much any more but lately one of my 13 year old twins has gotten into listening to music. I need to replace the ancient reciever that I have had for years too. (It has scratches when you adjust the volume.) Any advise on trouble shooting the speaker problem woudl be great. I bought them new in the late 80's or early 90's and am really attached to them.
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
Post edited by xjghost on
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited August 2011
    welcome to the forums xjghost, If they have a fuse check those first.I believe they are 1amp fuses, that's about the extent of my trouble shooting knowledge. . Put monitor 10s in the search, it came with over 11 pages of information.Maby you can get more from there, when I got one pair of monitor7s the tweeter didn't work, I replaced the fuse and It worked.There are some smart people here I hope they can help you more than I could. Good luck to you Dan
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2011
    In addition to the aforementioned advice...swap the tweeters and see if the problem follows the driver.
    Fuse = 1A 250v
    As far as the static issue, clean the potentiometer. Get a nice quality contact cleaner like Caig CaiKleen A/V but your best bet is to invest in this....
    http://store.caig.com/s.nl/it.A/id.2038/.f
    It's got everything you need to cleanup and tuneup all your gear and whatever you may find down the road.
  • xjghost
    edited August 2011
    I do not see a fuse on them. Swapped the tweeters and the "bad" or flat sound stayed.
  • xjghost
    edited August 2011
    I hooked my reciever up to another set of speakers and the "flat" sound is in them too. I am guessing my ancient reciever is about to bite the bullet. I was thinking a Denon 5.1 with about 100 watts or so might be a good replacement and not break the bank. Any sugestions?
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited August 2011
    xjghost wrote: »
    Play with the pots and see if anything clears up. I had this problem with an old Marantz and all it took was some Dexoit.
  • gwg_97
    gwg_97 Posts: 332
    edited August 2011
    If you go with a new receiver, I'd go with one that has pre-outs for each channel. This will allow you to add external amplifiers as you feel is necessary. It makes a huge difference.
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
  • xjghost
    edited August 2011
    gwg_97 wrote: »
    Had not thought about that.... but then again by the time I can afford that many amps it will be needing replacing. LOL! I'll see what is out that then. I live in a rural area of South Carolina so my looking has been limited to the net and Best Buy.
  • xjghost
    edited January 2012
    OK an update. I ended up getting a new receiver. Not what I wanted but what I could afford. It is the receiver that is acting up. My new Denon sounds great. I have to figure all this surround stuff out though. I have a new problem. I have all my sources, xbox, ps3, cable, going to the TV and an optical cable to the receiver. While watching a blue ray this weekend I noticed it sounds like there is an echo. I don't have anything for a center channel yet and the surrounds are going to have to be replaced and mounted because of the way the room is. Any thoughts on what to look into with the receiver to make it sound right?
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2012
    Need to know what receiver you got besides Denon? You probably have some kind of effect on like hall or club that is making it sound like an echo.
  • xjghost
    edited January 2012
    Denon 1613 or 1612. I'll look into that tonight.
  • xjghost
    edited January 2013
    Reciever is decent for movies but sucks for listening to music in the house. Need to find something reasonably priced and that can run my polk's like my old Keenwood did. Denon's new 75wpc is weak at best. Any recomendations on used gear that is a bargain woudl be great. I was thinking some 80's or 90's Adcom or Yamaha or Onkyo...
  • gmjungbluth
    gmjungbluth Posts: 232
    edited January 2013
    I have had this problem with my television when I had the tv speakers and the speakers running through the receiver both on. The way I fixed it was to go into my television's menu and select 'internal mute' or something like that - it shut off the tv speakers but kept the sound running out of the line outs to the stereo.
    Another thing you could try would be to run all of your sources through your Denon AVR, and use it as a video pass-through to your TV. Maybe that will eliminate the echo by having the AVR to all the processing of sound and video signal itself.
    xjghost wrote: »
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
  • xjghost
    edited January 2013
    Oh the echo is the tv and the stero being up. Solution was to turn the tv down all the way. I really think I need a amp preamp to be happy listening to music on the polks. Been looking around ebay lately to see what was out there for less then $500. I inhereted a haffler 500 but it appers to have a problem. I'll know more later in teh week I hope.
  • xjghost
    edited April 2013
    Ok Thought I would update this thread. I got the Haffler 500 fixed. $100... not bad imho. Bought an Onkyo P-301 pre amp for $71 + shipping and have my Technics 1400 turntable for $75 playing through it and its all sounds amazing! So I built a basic vinyl system for about $300.00 which I dont think is bad at all. I have clipped the Hafler already which tells me its either too old or not powerful enough for my taste. LOL!
