first hand opinions needed.
soundfreak1
soundfreak1 Posts: 3,414
edited August 2011 in 2 Channel Audio
Anyone have or have heard the tivoli model 2 . Looking for a background system, for going to sleep. Not criticle listing! Something I can play my EVO through. Want more than an ipod dock but don't want to run my main sys. All night and waste my tubes while I sleep. This unit looks perfact for what I want and have an oppertunity to pick one up used. Are they worth the 200. Or so they go for. And how do they sound?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    They sound really good for what they are. A small table top radio.
    They go for about 300 new so you have to decide if the price is good.
    You can also get a second speaker, a sub and a CD player to match.
  • nwohlford
    nwohlford Posts: 700
    edited August 2011
    I have an older version of tivoli model 1 (~8 years old) in the kitchen and gave a listen to the model 2 at the time. It is great for background music. The model 1 does an incredible job with spoken voices. I rarely use it for music anymore since my main system is in the room next to the kitchen in my current house.
    In general, I really like the Henry Kloss designed radios. I have an old Cambridge Soundworks Model 88 that I need to fix up.
    I am not sure about the worth $200 since I have not compared it to what else is out there, but it does seem like a good fit for what you want.
  • Joe08867
    edited August 2011
    Compared to what is out there it is a steal. Other radios of the type are plastic crap in comparison.
  • soundfreak1
    edited August 2011
    Thanks for the input. They have a certin cool factor as opposed to a bose radio ( ewe) just don't what something distracting . Just a nice soft sound to dose off to . Stream some fourplay and snooze.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
