Best subwoofer for about $200?
kazaam
kazaam Posts: 92
edited August 2011 in Speakers
Would it be the Polk PSW505? I really really really dont wanna spend a lot and will probably be going without a sub for a while.
Would the M70s produce decent enough bass that not having a dedicated sub for a while wouldnt completely suck?
Post edited by kazaam on
  • nhhiep
    nhhiep Posts: 877
    edited August 2011
    PSW505 or BIC F12 is your best bet. what from I am reading, the BIC is a little cleaner, tighter, but the 505 is louder/deeper.
    yep, the M70s won't give you enough bass, unless you have a top of the line AVR or bi-amp that thing with a separate amp.
    http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
    edited August 2011
    Or you could spend the 200 bucks on....some pie.
    Thats your que Mike.
    Or how about a subwoofer that looks like pie, now I would be in for that product.
    Seriously, the 505 is a good sub and plenty of others too, Bic, Epik, HSU, just to name a few decent budget subs. Look for a used one to save some coin.
  • kazaam
    kazaam Posts: 92
    edited August 2011
    I have this one that came with my HTiaB, it can't be worse than having no sub right? Upgrading kind of sucks because you have to upgrade everything, ughhh. I definitely can't spend anymore until I at least pay off the speakers I just bought. :(
    Type: Bass-reflex
    Input sensitivity/Impedance:
    140 mV/20 kΩ
    Maximum output power: 290 W (Dynamic power)
    Frequency response: 25 Hz–150 Hz
    Cabinet capacity: 37 L (1.3 cubic feet)
    Dimensions
    (W ? H ? D): 275 ? 507 ? 411 mm
    (10-13/16" ? 19-15/16" ? 16-3/16")
    Weight: 11.6 kg (25.6 lbs.)
    Drivers unit: 25 cm (10") Cone Woofer
    Power supply North American:
    AC 120 V, 60 Hz
    Power consumption North American:
    163 W
    edited August 2011
    kazaam wrote: »
    Doesn't hurt to try it out and see how it sounds. I wouldn't expect miracles though.
    Mike, you da pie man.:biggrin:
  • Monster Jam
    Monster Jam Posts: 919
    edited August 2011
    Keiko wrote: »
    How about some PIE that looks like a college coed? :cool:
    :wink:
    Check out that vintage TV!!! :eek:
    Do you hear that buzzing noise? :confused:
    gudnoyez Posts: 8,174
    edited August 2011
    Get a PSW111 thats what I have it gives a punchy amount of bass for filling in the lows that your 70's wont produce and does pretty decent when watcing Blu rays I see amazon has them on sale at $189 thats a pretty good deal I listened to the 505 and the Psw10 and liked this one the best.
  • kazaam
    kazaam Posts: 92
    edited August 2011
    How do you guys feel about the bic f12 vs the psw505?
  • BeefJerky
    BeefJerky Posts: 1,320
    edited August 2011
    Keiko wrote: »
    :wink:
    Sure, I'd love one of those! Actually, I'd like a pair for more...um...displacement. But then, a pair of those would actually end up being a quad of...well, you know. I'm sure I could make it work...
  • brgman
    brgman Posts: 2,859
    edited August 2011
    I’M OFFENDED!!!!
