Who makes the most bullet proof Electrolytic caps
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    OK the FC are available in 4700uf at 16v and 25v.
    FC -4700uf 16v =16mmDx31.5mm 7.5mm spacing ($1.91 ea)
    FC -4700uf 25v =18mmD x35.5mm 7.5mm ($2.68ea )
    FC -2200uf 6.3v =10mmDx25mm 5mm ($.90 ea)
    FC -2000uf 16v =12.5mmDx25mm 5mm ( $1.13)
    There is a considerable price break for quantities of each value of 50 or more but highly unlikely you'll need that many of any certain value.
    pitdogg2 Posts: 27,055
    edited August 2011
    FTGV wrote: »
    Digikey? I just got off the phone with a tech at Digikey and was told nothing in FC to meet my needs. In umc? maybe
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    Yep right out of the digi key cat.The part #'s are in order.Unless they are out of stock?
    P10263-ND
    P10289-ND
    P10204-ND
    P10257-ND
    edited August 2011
    FTGV wrote: »
    P10263-ND
    P10289-ND
    P10204-ND
    P10257-ND
    Well I have a catalog coming and according to Digikey CS there will never be another this will be the last one. I told him what I needed and the sizes and FM/FC were not them. Other makers I personally never heard of. Oh well thanks for helping.
    edit: just used your numbers seems even calling and talking to the "tech's" can get the run around. According to your cat numbers they have 100's of thousands of those...Seems I'll wait to get a catalog to look at and go from there so maybe i can one stop shop.
    thanks Ivan
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    That blows.:frown:I much prefer using the printed cat. vs online.I guess this is a cost cutting measure as it must cost a bus load to print and ship multi thousands of these massive beasts.
    thanks Ivan
    Since the FC series is also available in a surface mount package I can only guess he was looking at the sizing for those instead of the hole through types?:confused:I bet if given the part # you would have recieved a different answer from him.
