Polk M20 upgrades
brainburst
brainburst Posts: 2
edited August 2011 in Speakers
My M20's always semed to sound to harsh to me. Wondering about a tweeter and or crossover upgrade. Any suggestions? Any specs as to existing crossover design?
Post edited by brainburst on
    EndersShadow Posts: 17,722
    edited August 2011
    brainburst wrote: »
    Its probably easier just to purchase a new pair from the Polk Monitor or RTi series (Monitor being more recommended based on price).
    Upgrading the tweeters and crossovers would be more expensive than outright replacing them.
  • brainburst
    brainburst Posts: 2
    edited August 2011
    Yeah I could just spend 200+ dollars on speakers I don't need or $100 or so to get these to sound better, maybe even better than the supposed better speakers if I get the right components...Great idea!
  • Upstatemax
    Upstatemax Posts: 2,800
    edited August 2011
    brainburst wrote: »
    You sound like the kind of guy that likes to put turbos on a Geo Prism...
    Plain and simple, if you look hard enough you can upgrade to a better speaker for the same money.
  • deronb1
    deronb1 Posts: 5,021
    edited August 2011
    Unless you want the experience of working on speakers, I agree with the others. You should be able to find a pair of TSi 100s for about 150.00 brand new. No harshness on those puppies.
  • rebuy
    rebuy Posts: 694
    edited August 2011
    I don't know about the M 20's but if you're getting "harsh" sound the problem might not be the speakers, Could be operator error. :eek:
    You have not disclosed enough information to recommend any move for any equipment upgrade.
    What kind of power are you using?
    Stereo or what?
    Got the treble up too high?
    You're not using a HTIB receiver are you?
    Maybe you're clipping your equipment. :cool:
