Can i daisy chain P.A 500.4 & P.A 250.2?
b_rad
I want to buy a 4 channel and a 2 channel to power 6 midrange speakers but dont know if it is possible to daisy chain these 2 amps together.
Is someone able to help me out with this? Much appreciated!
Post edited by b_rad on
Not sure what you mean by "daisy chain" but PA500.4 has a master/slave switch which allows you to connect it to another PA amp so you would get power and # of channels of both amps while controlling/tunning from 1. Basically lets you connect a whole bunch of speakers/amps and not lose control over them.
Not sure if PA250.2 has that same switch but i would assume it does.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
technically you could connect ur head unit to 200 amps by just splitting the signal.... is that what ur asking?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
ok i thought that some of the pa amps couldent hook up togeather becuse they need to have the same power rating or something?? is there any problem with me haveing the 4 chan as the master amp and the 2 chan as the slave??
As long as 2channel has that switch - no problem, that's exactly what that switch is for.2008 Nissan Altima
Kenwood DNX 5140
if you are running the SIGNAL wires from one amp to another, you can do that for as many amps as you have.
you cannot daisy/join anything on the output side of things tho. but there are other brands where you can join/concatenate the outputs of two smaller powered amps to drive one larger load.
