Diy sub tweaks/additives ?
polkanddie
I am running a Dayton spa500 with a jvc arsenal 12" 600w rms in a 1.5 cubic foot enclosure. I was wondering is there anything I could do to make it louder or cleaner sounding,maybe dynamat inside or anything? What are some things you guys have done? Also what kind of settings should I keep it at like crossover and phase and freqency setings ... I'm really new at this. Thanks guys
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
Onkyo tx sr 503
SUB(DIY)
Post edited by polkanddie on
polkanddie wrote: »I am running a Dayton spa500 with a jvc arsenal 12" 600w rms in a 1.5 cubic foot enclosure. I was wondering is there anything I could do to make it louder or cleaner sounding,maybe dynamat inside or anything? What are some things you guys have done? Also what kind of settings should I keep it at like crossover and phase and freqency setings ... I'm really new at this. Thanks guys[/Quote
Are you sure the the 1.5 cubic size is big enough ?
Have you tries the sub in the cornor ? -
Mount it on spikes to decouple it from the floor. This will clean it up some.
My HT room has a laminate floor which, in my experience, is bad about transmitting vibrations and basically becoming a large transducer. I have my sub placed on a heavy flagstone slab and it helps reduce that effect drastically.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
I added a good amount of polyfill to make up the extra .5 ft I really needed. I just can't have it too big. I'll give the corner a shot! Thanks. I bought these large lag bolts, do you think they will be suitable for use as spikes?TV- Insignia 46'' LED,1080p,120hz
Onkyo tx sr 503
SUB(DIY)
"sticking feathers up your butt does not make you a chicken"-Tyler Durden -
Do you have a laptop that ca be plugged into your avr like an ipod? if so you can download a tone generator and we can take it from there.Too much **** to list....
polkanddie wrote: »I added a good amount of polyfill to make up the extra .5 ft I really needed. I just can't have it too big. I'll give the corner a shot! Thanks. I bought these large lag bolts, do you think they will be suitable for use as spikes?
Polyfill adds 10% cheapest place is at fabric stores .
Decoupling may change the tone but it will decrease the bass , auraflex sells sub pads but before you spend a cent on a pad try setting it on some foam pads and see if it sounds better .
I have never been a fan of spikes decoupling a sub would be removing the bass wave from the ground so=less bass .
But in the case of wooden floors it would help especially w/mids .
But the corner loading will increase the bass tons .
