Misc Polk Parts + Speakers + TC Sounds
VR3
VR3 Posts: 28,800
edited September 2011 in For Sale (FS) Classifieds
Sorry for so many duplicate posts - trying to organize the stuff I have accumulated the last few months...
1) SDA CRS+ enclosures + Walnut veneer to refinish - $150.00 shipped (Veneer cost 130 on its own) - enclosures have been stripped to the MDF - Pics upon request
2) SDA CRS Original Enclosures - $100 shipped - overall good shape (pics upon request)
3) RT3000P amplifiers x 2 - do not function, original owner disconnect multiple connections and spliced wires. All circuit boards and trannies are intact - $80.00 shipped
4) SDA CRS Passive Radiator (10") x 2 - $28.00 shipped each
5) SDA CRS+ Passive Radiator (10" x 2 - $28.00 shipped each
6) SL2000 x 4 - $20.00 shipped each, all tweeters were tested with WT3
7) Blade Blade SDA Cable - OEM $40.00 Shipped
8) Polk Audio CRS and CRS+ grills $20.00 shipped per set
Speakers for sale
1) Definitive Technology BP2006TL x 2 - great shape, caps are missing grill guides and just lay on top of speaker. I plan on ordering replacements before they ship so it is a null point but I feel it should be said as they are currently in that condition. One plate amp has been replaced as the original was distorted. $350.00 shipped pair - bomb proof packaging
Dual 4.25" midbasses, 8" woofer, dual 1" tweeter and a 150 watt amplifier
2) Yamaha YST-SW300
Driver 12-inch cone
Amplifier Built-in 185 watt Yamaha Active Servo Technology
Frequency Range 18 Hz - 160 Hz
High-Cut Filter Continuously Variable from 40 Hz - 140 Hz
High-Pass Filter Adjustable at 50, 80, 100 Hz
Dimensions (W x H x D) (15-3/4 * 19-3/4 * 17in.)
Weight 57 lbs.
GOOD overal condition - Looking for $150.00 shipped - will post pictures upon request
3) RT3000P tops - fully functional, overall good condition, grills in good condition
$220 shipped - BLACK - Pics upon request
TC Sounds -
1) TC Sounds LMS-R 12
$250.00 shipped literally 30 minutes of use, sells for 370 new - I have original box, screws and manual
2) TC Sounds VMP 18
$170.00 Shipped - literally 30 minutes of use, sells for 280 new - I have original box and screws
Everything is OR BEST OFFER
I want everything gone, FAST!
Post edited by VR3 on
    Tony M Posts: 11,201
    edited July 2011
    Man your killin me.... I want the rt3000p amps but ....
    So somebody took the connectors off of the circuit board and wired directly to the leftover pins or something like that. The connector joints are not factory assembled anymore? If they are, I'd like to buy them and have Polk fix them down the road if possible since I'll be keeping my set for life..
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2011
    You sold everything (right?) from TWO working pair of CRS, why not sell them whole?
    edited July 2011
    If the connectors from one end to the next are spliced back together, I can live with that. I would like to have all connectors though no matter what if you still have them.
    Put me in line first, please.
    VR3 Posts: 28,800
    edited July 2011
    Hey Tony - I will take pictures of EXACTLY what state the amps are in... - I will include ALL wiring from driver to amp and from the front volume control. Alot of the wiring has been cut and electrical taped over - From what I can tell if someone were to reconstruct the wire you should have a functional amplifier. The owner described the amp to a make a dut dut dut sound and he just direct wired the drivers after that.
    Russ,
    I have my reasons and I am sure I would love to discuss them with you in person at a Polk fest one day but for now I will simply say this - the only way I was selling those speakers whole was if I went through and properly fixed them up, modified them and made them right. The stars did not align for me on these and I don't have the time to adequately fix these up to where I would feel comfortable.
    VR3 Posts: 28,800
    edited July 2011
    Here are amplifier pictures
    Also Tony since you are in Wilmington - something to consider... if you want to meet half way you can have the amps and tops for 200.
    I plan to keep the subs and use them in my two channel system. They are EXACTLY what I was looking for and I will either put in a plate on the back and put speaker terminals or I dont know! lol
    edited July 2011
    PM sent..:wink:
  • Conradicles
    Conradicles Posts: 6,142
    edited July 2011
    Trey, if you and Tony meet I'll help with a bit of gas money to bring me some bookshelf speakers I want to buy from him. PM me if it all works out.
    VR3 Posts: 28,800
    edited July 2011
    we will make it happen... Just buy me a frosty and some gas hehehe
    VR3 Posts: 28,800
    edited July 2011
    The RT3000P amps and tops are SOLD as of right now
    Everything else is available - I will try to get some pics up as well...
    Get em while they are hot folks!
    VR3 Posts: 28,800
    edited July 2011
    Here is the Yamaha sub --
    Has quite a few scratches on top but are not too noticeable unless you are right up on it
    The side has some small scratches too
    From what I can gather about this sub -
    http://www.audioreview.com/cat/speakers/subwoofers/yamaha/yst-sw300/prd_120836_2741crx.aspx
    MSRP was 600 - sold regularly for 350-400
    I am looking for 170.00
    EDIT: I did a shipping quote and with the foam I buy it will cost me around 70 - looking to net out 100 on the sub... at 170 it is a steal. You can also pick it up for 100 bucks :)
    Rated down to 18hz
    VR3 Posts: 28,800
    edited August 2011
    1) SDA CRS+ enclosures + Walnut veneer to refinish - $150.00 shipped (Veneer cost 130 on its own) - enclosures have been stripped to the MDF - Pics upon request SOLD
    3) RT3000P amplifiers x 2 - do not function, original owner disconnect multiple connections and spliced wires. All circuit boards and trannies are intact - $80.00 shipped SOLD
    4) SDA CRS Passive Radiator (10") x 2 - $28.00 shipped each SW100
    5) SDA CRS+ Passive Radiator (10" x 2 - $28.00 shipped each SW102 SOLD
    8) Polk Audio CRS and CRS+ grills $20.00 shipped per set ONE SET LEFT
    Speakers for sale
    2) Yamaha YST-SW300
    Driver 12-inch cone
    Weight 57 lbs.
    $220 shipped - BLACK - Pics upon request SOLD
    TC Sounds -
    2) TC Sounds VMP 18
    VR3 Posts: 28,800
    edited August 2011
    Also available
    Definitive Technology Pro Cinema center 2 - $80.00 shipped (see pics)
    Polk Audio CRS+ inductors that mount to the crossovers...
    Im thinking... 12 shipped for the pair?
    VR3 Posts: 28,800
    edited August 2011
    I could almost ship this stuff WITHOUT boxes ;)
    haha
    VR3 Posts: 28,800
    edited August 2011
    1) SDA CRS Original Enclosures - $100 shipped - overall good shape (pics upon request)
    Enclosures are OAK VENEER - the veneer is in great shape except for some minor blemishes. My original goal was to refinish these as they are in great condition for the age!
    2) SDA CRS Passive Radiator (10") x 2 - $28.00 shipped each SW100
    3) SL2000 x 4 - $20.00 shipped each, all tweeters were tested with WT3
    4) Polk Audio CRS grills $20.00 shipped (one set)
    Speakers for sale
    2) Yamaha YST-SW300
    Driver 12-inch cone
    Weight 57 lbs.
    GOOD overal condition - Looking for $170.00 shipped - will post pictures upon request
    3) Definitive Technology Pro Cinema center 2 - $80.00 shipped (see pics)
    TC Sounds -
    2) TC Sounds VMP 18
    This is everything left at this point
    VR3 Posts: 28,800
    edited August 2011
    bump
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2011
    Is there any place to buy a pre made enclosure that'll fit that 12?
    VR3 Posts: 28,800
    edited August 2011
    It can be used in multiple sizes 1.5 cu ft and up
    VR3 Posts: 28,800
    edited August 2011
    TC Sounds pictures
    The last pic is the TC Sounds PR versus a "regular" pr.
    Note the awesomeness.
    VR3 Posts: 28,800
    edited August 2011
    Surprised no one is jumping on the BP2006tl - they easily sell for 500 shipped all day on Audiogon... once I throw on the new grill guides they will go on Agon for 500 shipped as well...
    Willing to hook up a a Polkie at a STEAL though. They sound great, easily an upgrade over all of the RTi series! :)
  • brgman
    brgman Posts: 2,859
    edited August 2011
    hmmm....i need to think about these
    I’M OFFENDED!!!!
    VR3 Posts: 28,800
    edited August 2011
    For the money you will -NOT- regret it, period
  • brgman
    brgman Posts: 2,859
    edited August 2011
    Is the plate you replaced on the 2006's OEM?
    I’M OFFENDED!!!!
    VR3 Posts: 28,800
    edited August 2011
    The plates are stock - they are OEM and they are painted, not vinyl.
    What is missing is the grill guides that hold the plate on. Not really missing but broken - but easily replaced.
    The tops I replaced were the 2004TL (which I already sold)
    VR3 Posts: 28,800
    edited August 2011
    More pics!
    THE CRS CROSSOVERS ARE -NOT- INCLUDED WITH THE ENCLOSURES.
    VR3 Posts: 28,800
    edited August 2011
    Rated down to 18hz
    160 shipped
    Bomb shelter packaging
    VR3 Posts: 28,800
    edited August 2011
    Bumpity bump bump
    Def Tech center, towers, Yamaha sub, TC sounds woofer and PR - Polk parts and much more!
    Get em while its hot :)
    VR3 Posts: 28,800
    edited August 2011
    Shout out to Tony - EXCELLENT buyer, very laid back and a great guy to boot!
    Was a pleasure to meet you and I am sure our paths will cross again in the future!
    Thanks for a smooth transaction and excellent communication!
    VR3 Posts: 28,800
    edited August 2011
    Get these LOADED (Passive radiators, tweeters, grills, enclosures) for - $215.00 SHIPPED
    Speakers for sale
    INCREDIBLE DEAL!
    2) Yamaha YST-SW300
    Driver 12-inch cone
    Weight 57 lbs.
    GOOD overal condition - Looking for $170.00 shipped - will post pictures upon request - NOW ONLY $150.00 SHIPPED
    INCREDIBLE CENTER CHANNEL!
    TC Sounds -
    $240.00 shipped literally 30 minutes of use, sells for 370 new - I have original box, screws and manual
    2) TC Sounds VMP 18
    $160.00 Shipped - literally 30 minutes of use, sells for 280 new - I have original box and screws
    PRICES HAVE BEEN LOWERED AND PACKAGE DEALS!!
    edited August 2011
    Trey, It was great meeting you too. Thanks for the DEALS:cool:.
    You we're right on time and your speakers and amps surpassed my expectations.:wink:
    Sorry for my rambleing on in that hot parking lot, I do that sometimes..:redface:
    It was smoooooth and easy working with you with that storm threatening and all. It turned out to be a great day (although hot as **#@) for a road trip! Thank you very much for meeting half way or more too!!
    I really thought about your Def. Tech. towers and just didn't get around to asking you about them and then there's my wife, she might not have liked my car getting packed full of speakers at this time.:redface: Sometimes is best to hold off for the greater good of a marraige.
    Maybe in time we'll meet again over those Definitive's after all.:wink:
    I'm going to leave some feedback now. Well it won't let me..later maybe..;-)
    Thanks again!
    VR3 Posts: 28,800
    edited August 2011
    lol! Def Techs would be an interesting show down with the RT3000p -
    They are small and compact but man do they throw down without problem!
    It was incredibly hot today! lol!
    Till next time Tony! :)
    Thanks again!
