What are these?
HTguru1982
Found them on CL. No model number listed. Any ideas?
http://stlouis.craigslist.org/ele/2521464850.html
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Post edited by HTguru1982 on
Looks like RTA-12. The speakers alone are worth more than that. I'd be surprised if that NAD receiver had enough juice to really run them, though.Ludicrous gibs!
I'm heading out now to pick them up. I picked up a Yamaha RX-V2500 receiver. Will that be able to power them? It's 130 watts x 7.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Subwoofer: SVS PB10-ISD -
It will power them, yes. Just be careful of your volume levels, or you may toast the tweeters.
I would recommend separate amplification, of course. Or a high-powered integrated. HT receivers aren't usually designed for this kind of load.Ludicrous gibs! -
I picked them up. The speakers are in good condition with a few nicks here and there. They sound amazing. I'm going to hold off on using the Yamaha with them until I can get a separate amp. The NAD seemed to power them fairly well so I'm going to use it for now.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
The model number is 7155.
After messing around with things, it turns out that the NAD is busted. The radio worked when I tested it out but none of the inputs work. Nothing but static on each one. I knew the cd player didn't work when I picked everything up so that only leaves the turntable and tape deck. I don't have any records or audio tapes so no way of testing them. Normally, I'd be super pissed but I only paid $120 and the speakers themselves work just fine.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Yeah, like I said... those speakers are worth more than what you paid for everything. I wouldn't be too upset about the other gear. BUT, you could look in to trying to fix what's wrong with the NAD on your own. Could be a simple fix... or not.Ludicrous gibs!
I probably will try to get the receiver fixed. From what I've read, it's pretty well respected. I would like to use it for a small music only system.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
