DCR Checkpoints for SDA's
Toolfan66
I just finished putting my 1.2tl's back together. Thought I would check the DCR values, on the test data sheet in the SDA sticky under 1.2/1.2tl models under R1 and R3 it says 2.2 for both right and left speaker mine measures 1.5 any reason I should be concerned??
All the others are dead nuts or very close the 3.0 is on the money and the 3.6 is measuring 3.5 and 0.0 is just that 0.0
Thanks!!
Thanks!!
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
SVS SB16 X2
Post edited by Toolfan66 on
Anyone???Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Did you do the crossovers?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yes. I did them awhile back when I got the boards from Ray..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Hello Larry,
If you look at the crossover schematic for the 1.2TL the measurements are dealing with the 16mH inductor that is the first thing pin 2 is connected to. Both of the tests are measuring the path through this inductor. Was this one of the parts you replaced?
Ken -
Kenneth Swauger wrote: »Hello Larry,
Ken
Yes with a Northcreek inductor, Funny you should ask as that was the first thing that popped in my head when I did the tests..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
It is possible the DC resistance of the coil is less than the original. This is assuming the coils of the MW6511 are within spec.
Yes, that's North Creek's claim to fame: http://www.northcreekmusic.com/COILS.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks Ken, and Mike.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
No problem, glad to be of help.
Cheers, Ken -
Man,, it's nice to have a "resident Ken",,eh folks?JC approves....he told me so. (F-1 nut)
Ken, Ken, he's our Man, If he can't do it Ogre can.
