Coax Length or increments
I'm about to replace the coax from the wall jack to the TV/radio signal splitter, then from the splitter to the TV and AVR. I know with RG-8 for Ham radios there are standing wavelength considerations and optimal increments for the jumpers.
Are there the same considerations for over-the-air HDTV and radio signal? If so, what are they? In other words...are the jumpers supposed to be a certain length. And is the long jumper from the wall socket supposed to be cut at certain increments??
Thank in advance,
1C
Too much **** to list....
  • WilliamM2
    edited July 2011
    No, just cut or buy coax in the length you need.
  • SDA1C
    edited July 2011
    OK thanks. The old I took off were 2 different lengths from the spliter to the tv and avr. I made the new ones the same and would you believe it. I picked up 4 more channels. I made 2 3 foot jumpers and the one from the spliter to the wall is now 18 feet. I think it made the difference balancing things out.
