Need recommendation on rears and receiver
I currently have a cs2 center, monitor 70 fronts, and a bic f12 sub. Which do you recommend getting for rears a polk monitor 60, 50, or 40? Also what receiver would be sufficient in powering this system? I am using the system for 85% movies, 10% games, 5%music.
Post edited by mikeyways on
Welcome to Club Polk!!
You could go with monitor 40's or even the 30''s will be good. Your surround speakers dont have to be so large. What is your budget for a receiver?Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
With 70's as fronts I would go for the Monitor 40's for the rears. Anymore is almost wasteful.
I have the 70s and 40s with the cs2,I really like the sound. Receiver is your choice,but something with preouts for an amp if you want to add one down the line.
