Sda srs help
cstmar01
cstmar01 Posts: 4,424
edited July 2011 in The Clubhouse
Here's the deal. I am going to pick up the sda srs that I bought finally but ran into a snag. The speakers are 21 inches wide and so I I lay them on their back they will not fit between the wheel wells of my suv or my friends truck.
Can srs be laid in their side safely? Would this harm the cabs at all? I want to make sure this goes smoothly as I'm on a tight schedule that day and want the babies to be safe.I figure if they go on their sides then just use a ton of padding between them and tie them down in the truck bed or suv so they don't move around or fall over.
Post edited by cstmar01 on
    Toolfan66 Posts: 17,366
    edited July 2011
    You should be fine just drive safe, and as you said use padding..
    F1nut Posts: 50,841
    edited July 2011
    Yes.
    No.
    One note of caution, do not slide them on their backs as the binding post cup sits proud.
  • cstmar01
    edited July 2011
    Thanks Larry and Jesse! I'm just super excited and want to make sure these arrive nice and safe.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2011
    Helped a buddy of mine transport some SRS's in a Ford Taurus wagon and we laid one on its back and the other on its side without any problems. Just make sure when you're putting them on there side try not to slide them into position, that could pull or tear the side cloth.
