Ubuntu Tar.gz file problem?
disneyjoe7
disneyjoe7 Posts: 11,435
edited July 2011 in The Clubhouse
I need some help, I have a file X.tar.gz and I can't expand it as it errors out.
gzip: stdin: invalid compressed data--format violated
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
If it's any help the file is from the Evolution backup 10.x.x ubuntu to Evolution ubuntu 11.0.4
Is there a way to recover this file?
Steve
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • bobman1235
    bobman1235 Posts: 10,822
    edited July 2011
    Can you show the command line arguments you're passing?
  • disneyjoe7
    edited July 2011
    Bob,
    I just trying to use it in the email program as restore file. And above is the error I get by clicking on file.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2011
    What happens at the command line with
    gunzip X.tar.gz
    If that works there should now be a X.tar
    Now try
    tar -xvf X.tar
  • disneyjoe7
    edited July 2011
    I tried gunzip in terminal right? Got this back.
    gunzip evolution-backup.tar.gz
    gzip: evolution-backup.tar.gz: invalid compressed data--format violated
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • quadzilla
    quadzilla Posts: 1,543
    edited July 2011
    Try just tar -xf X.tar.gz. If it expands, it wasn't really a gzipped tar file, just a tar. If it still doesn't, it's either not really a tar file, or it's corrupted and you need to try downloading it again.
    You could also try to determine the file type with head -1 X.tar.gz and see what the first few characters on the line are. gzip files will say, IIRC, gzip.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • bruss
    bruss Posts: 1,039
    edited July 2011
  • disneyjoe7
    edited July 2011
    So this didn't work...
    steve@steve-MXC051:~$ tar -xf evolution-backup.tar.gz
    But this did something different....
    steve@steve-MXC051:~$ tar -xvzf evolution-backup.tar.gz
    .evolution/
    .evolution/mail/
    .evolution/mail/searches.xml
    .evolution/mail/pop/
    .evolution/mail/local/Inbox.ibex.index
    Confused.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • bobman1235
    edited July 2011
    The "v" is just a verbose flag, so that's why it was "different." it gave you more information.
  • disneyjoe7
    edited July 2011
    Bob, Thanks..
    So what is this telling you?
    .evolution/mail/local/Outbox.ibex.index.data
    .evolution/mail/local/Templates.cmeta
    .evolution/mail/local/Bills.cmeta
    .evolution/mail/local/Save
    .evolution/mail/local/Sent
    .evolution/mail/local/Drafts.ibex.index
    .evolution/mail/local/Sent.ibex.index.data
    The last lines before it stops.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • bobman1235
    edited July 2011
    Not really sure, it looks like it at least starts to decompress and then hits a corrupted part o f the file? If it weren't really a valid archive it wouldn't be able to read the directory structure like it does, so obviously some part of it is correct. Can you re-download or find a new source for the download?
  • sucks2beme
    sucks2beme Posts: 5,614
    edited July 2011
    Odd. Compression on a compressed file?
    TAR is already compressed. Why is it also GZ?
  • bobman1235
    edited July 2011
    TAR does not compress, it merely groups a bunch of files into a single file. GZIP does the compression but only works on single files (unlike on Windows or Mac OS).
  • disneyjoe7
    edited July 2011
    I'm screwed,,,, I did the backup but I rewrite the hd to update the ubuntu to 11.0.4
    I did something wrong on my old 10.x.x, I deleted the network-manager so I couldn't get back on line to fix it. So this why did what I did.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
