1st Mod Update
deronb1
deronb1 Posts: 5,021
edited July 2011 in DIY, Mods & Tweaks
The sound of my speakers (RTA 8Ts) have undergone a couple of transformations since the mod. I haven't put 100 hours on yet, but have been running them a lot.
At first, there was little change, then they seemed more "alive" but the mids (mostly vocals) sounded a little distant. Now things seem to be more even. Is this usually the case after a modification?
Brighter sound, but still fast and accurate. Seems to have a bigger soundstage, but have lost the warmth (especially in vocals) that I have been accustomed to.
Actually, they seem to be better for HT now. I am curious to know if Mylar caps are inherent to a warmer sound or was it just my speakers?
  • Face
    Face Posts: 14,340
    edited July 2011
    What parts did you use?
    EDIT: Do you still have the original tweeters installed?
  • deronb1
    edited July 2011
    They were inexpensive Bennic high pass and low pass poly caps. Yes, the original tweeters remain.
  • Face
    Face Posts: 14,340
    edited July 2011
    I would replace the tweeters first with a pair of RD0-194's from Polk, they are a much better tweeter all around and will fix your brightness issue.
    Although, Bennics are inherently a tad bright. If Polk's new tweeters do not fix your issue, try some Claritycaps in the HF circuit instead.
  • deronb1
    edited July 2011
    Sounds like a plan. I don't hate the sound now. It's just different than what I have been use to.
    Will give them more time and see what happens. I like the thought of just replacing the tweeter instead of having to go through all that again. That said, it was kinda fun.
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    You need about 100hrs of burn in on new caps before they settle down and smooth out.
